Dear All
Maybe this is a stupid question, but I have without luck searched around both the in the manual, forum and the BBB for a procedure how to remove and take out and replace the barrel bushings in the main throttle linkage cross rod right end. See attached drawing, I found in the forum, where the rod is nr. 30, barrel bushing is nr. 41 and the bushing is fixed into the bracket nr. 40.
I can see that there is some lock rings involved, but they seem to have already been taken out, but the bushing does not come out.
Also, I have to confess that I have never removed the main throttle linkage rod before, so the best procedure to remove it would also be very welcome.
So before I start improvising myself, then I would just like to hear, if someone can help me out with some good tips or a link to a procedure how to do it in the correct way.
Christian
