Author Topic: Brake Compensator Adjustment  (Read 1870 times)
Kevkeller
  • USA, HI, Honolulu
« on: January 24, 2022, 21:10:42 »
Here is an article posted by a defunct website called Oldtimers regarding the compensator.  They built a device to check and adjust it.  I am in the process of making one also.
When I had my compensator apart there was some corrosion in the bore and it probably does not work correctly.  I think I will bore it out and put a brass sleeve in and readjust it.
If I get the device built I will check others if anyone wants.
1970 280 SL
Re: Brake Compensator Adjustment
« Reply #1 on: January 24, 2022, 21:52:36 »
You can send it off to be rebuilt, tested and restored. PMB performance. I can't remember the price, but wasn't that much and several have used them on this site. Or you can build a testing fixture you will use once. If you have the time to do so, that can be fun also. Just depends on your situation.
Jordan
  • Canada, ON, Jordan
« Reply #2 on: January 24, 2022, 22:34:05 »
Not sure what the cost is to rebuild/restore but you can get them new.  Here is one from Alfa Romeo. I don't know how the cost compares to MB.
https://classicalfa.com/br012-1-oe-brake-pressure-regulator-valve-oe/
Marcus
66 230SL  Euro 4 speed
Kevkeller
  • USA, HI, Honolulu
« Reply #3 on: January 24, 2022, 23:53:24 »
I don’t mind trying to fix it but if I screw it up I’ll now know where to find a new one. Thank you.
« Last Edit: February 06, 2022, 10:28:34 by Kevkeller »
1970 280 SL
« Reply #4 on: January 25, 2022, 01:32:04 »
Keep in mind the Alfa unit is tuned for an Alfa.  They are most likely exactly the same unit but with a different setting. You "could" swap the spring and housing with the adjustment screw and retain the adjustment.  I do often wonder if we could eliminate some of the nose dive by using a different adjustment?
« Reply #5 on: January 25, 2022, 05:20:17 »
I kind of thought that the brake force regulator only acts on the rear disc brakes. It keeps the rear brakes from locking up in heavy braking situations which is a sure way to end upside down in the Pumpkin patch if they ever do.  :( :-[
You might be thinking about a brake bias regulator which is a different device.
Kevkeller
  • USA, HI, Honolulu
« Reply #6 on: January 25, 2022, 07:41:35 »
Maybe I called it the wrong name but it’s what you are talking about, reducing the pressure to the rear brakes.
1970 280 SL
« Reply #7 on: January 25, 2022, 09:04:00 »
No, you had it right. Just wanted you to understand that these are two different devices.
Kevkeller
  • USA, HI, Honolulu
« Reply #8 on: February 05, 2022, 19:42:36 »
Finished the boring. Came out nice.
« Last Edit: February 06, 2022, 10:30:59 by Kevkeller »
1970 280 SL
