Please check out joining the Emergency Contact List for help during your travels!
I bought mine from Mercedes in 1995 part number 930-150-00-18 and they are similar to the ones Charles posted but are labeled with "Bosch-7MM Silicone-High Temperature" and has the 90 degree at the #1. They have Bosch metal ends 1 ohm as shown in my picture.Does anyone know where I can get a straight Bosch metal end for my #1 to match my other 5? Also I noticed that they can be unscrewed from the wire but can't seem to unscrew mine. Am I missing something?
Yep, that carbon core wire will add an additional 5K ohm resistance to each spark plug circuit. Not a good idea, especially if you are using the old original ignition and coil.
Interesting Dan, if you think about it, the resistance will increase with the length of the wire?. Cut it in half and check again to verify
