Author Topic: blower fan wheel  (Read 5624 times)
ricSL
blower fan wheel
« on: January 27, 2022, 18:07:11 »
I need a fan wheel for the heater blower part # 0008350704 I just need one it does not matter L or R side if someone out there happen to have one or the complete heater housing unit to sell I'll be interested, 1967 230sl.
Thanks, Ric
Re: blower fan wheel
« Reply #1 on: January 27, 2022, 20:07:42 »
Hi Rik,
I have one available.
It in Europe, very expensive to get it to the USA.
Better to check first in USA.
ricSL
« Reply #2 on: January 27, 2022, 20:38:01 »
Hello Peter,
Thanks for checking in, what will it cost to ship it to Chicago Illinois 60609 and what condition is the fan in, phot will help.
Thanks, Ric
« Reply #3 on: January 27, 2022, 22:13:45 »
Ha Ric,
Some pictures and I send you a PM.
sandcrab59
  • USA, MA, Lunenburg
« Reply #4 on: January 28, 2022, 02:09:04 »
Hi Guys:
I am looking for the same fan .
I dropped mine during assembly and broke 3 blades.
Any help would be appreciated.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #5 on: January 28, 2022, 08:40:38 »
Tom,
Depends how it is broken.
If you still can glue (two components) it with small internal metal splints it is repairable.
With the splints it will be strong enough to resist the forces.
sandcrab59
« Reply #6 on: January 28, 2022, 12:38:19 »
The 3 blades broke off in one section, and one blade broke off.
I glued the section (in the middle of the fan) back together with epoxy , and it held great.
The one broken blade I also epoxied back and it held well.
I tried it with my battery and it spun perfectly, but at the final spin I could see
a very extreme minor wobble.
That should not bother its performance. BUT in the long run that single blade could break off .
So now I would have to get under the dashboard and pull out the motor.
So since it is out of the car, (I am restoring the complete dashboard) I would rather put in a not broken fan.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
m300cab
  • USA, Pennington New Jersey
« Reply #7 on: January 28, 2022, 18:59:16 »
I believe I have one from a 111
any idea if it's the same?
Michael Parlato
sandcrab59
« Reply #8 on: January 28, 2022, 20:50:29 »
I have no idea.
But if you look at the 3 pictures from Peter above , that is the correct part.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
sandcrab59
« Reply #9 on: January 28, 2022, 20:56:09 »
I do not know what car is a 111.
If you look at a parts catalog for a 111 and under the section 83, Heating and ventilation , you will see the fan.
The fan # is A 0008350704.
If that is the same number for a 111 then it is the correct fan.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
sandcrab59
« Reply #10 on: January 30, 2022, 16:17:15 »
I found the 111 car and the fan is not the same.
In the 111 car the fan is part of the motor.
It is completely different.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #11 on: January 30, 2022, 16:24:28 »
Just checked, the blower fan for W113 was used only in W113.
sandcrab59
« Reply #12 on: January 30, 2022, 17:55:28 »
Powell:
Did we meet in Germany in 2013 at the 50th Anniversary?
See if you can locate that fan for me, if possible.
You were next on my list to contact. You beat me to it.
Tomasz
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
« Reply #13 on: January 30, 2022, 18:12:04 »
Tomasz, I do not think so, in 2013 my car was still in boxes...
I will ask around, no problem.
