Author Topic: Yet Another Distributor Question  (Read 2523 times)
DavidAPease
  • USA, CA, Chico
« on: January 30, 2022, 18:48:37 »
Hi, all,
This question goes back to one I asked on the forum way back in 2005, and we never really found an answer for.
I just took my '66 230SL (automatic) to a mechanic who hasn't worked on it before.  He was somewhat flummoxed to see a distributor with the number 0 231 185 008.  It appears to be a vacuum advance distributor, but according to our Technical Manual my engine (no. 12-003868) was built well after the switchover to vacuum retard.  (https://www.sl113.org/wiki/Electrical/Distributor#SL230)
I've attached a (poor) photo of my throttle body which, according to the photos on this page in our Technical Manual https://www.sl113.org/wiki/Fuel/Throttle#Body, looks more like the vacuum attachment for a vacuum retard system.  (However, the Benz Dr. has pointed out that there were several different throttle bodies used, so I don't know if that's definitive.)
So my bottom-line question is this:  My cars seems to have good power, runs smoothly, etc.  Is it possible to mate a vacuum advance distributor to a vacuum retard throttle body and have it work well?  (Or is there something else I am misunderstanding?)
      Thanks for any insights,
             -David
-David Pease
DavidAPease
  • USA, CA, Chico
Re: Yet Another Distributor Question
« Reply #1 on: February 01, 2022, 00:01:49 »
So I've just confirmed with the mechanic that my throttle body is indeed a vacuum retard (which is correct for my engine), but my distributor is vacuum advance.  This seems to explain some of the idling problems I've been having.
I am about to post a Want-To-Buy for the correct distributor (051).
          -David
-David Pease
« Reply #2 on: February 01, 2022, 04:17:33 »
Switching throttle bodies will make your engine run like dog doo. Vacuum retard is ported at the bottom of the TB and VA is at the top.
DavidAPease
  • USA, CA, Chico
« Reply #3 on: February 01, 2022, 04:23:16 »
Thank you, Dan.
It seems that the distributor rather than the throttle body got switched some time in my car's life.  It will get un-switched soon.
        - David
-David Pease
MarkCan
  • Canada, Ontario, Mississauga
« Reply #4 on: February 12, 2022, 15:12:10 »
          -David
David,
What is your distributor part number?
I’ve rebuilt one recently for the 66 230 and it’s a vacuum retardant.
Bosch 0 231 116 047. This unit was correct for some 230 towards the end of production as well as some early 250. Performance was very similar to the 051 unit with minor differences in lower rpm range (idle).
DavidAPease
  • USA, CA, Chico
« Reply #5 on: February 13, 2022, 01:34:38 »
Hi, Mark,
I've already bought an 051 distributor from Dirk Balter, and it is installed and running well.  (My old, incorrect one ran surprisingly well, too!)
Thanks for the offer.
            -David
-David Pease
dirkbalter
  • USA, CA, Corona
« Reply #6 on: February 13, 2022, 04:33:46 »
David,
Happy to hear it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
