Author Topic: Timing Chain Failure  (Read 35858 times)
Re: Timing Chain Failure
« Reply #50 on: January 19, 2006, 17:38:52 »
And that's why you pay me the big bucks. ( well, sort of) I go to great lenghts to make sure I make no mistakes while building engines. Keep me away from your rad cap though..........
Skitzerow
« Reply #51 on: July 24, 2006, 18:44:37 »
Well I am getting my engine back together and got my new crankshaft sprocket gear.  I think somewhere along the way my chain may have slipped a link.
But if you look at these pictures you will see how much wear was on the old sprocket gear versus the new one. I have to say all my other idler sprockets and camshaft sprockets look great.  May have not worn much because the others are bigger and would distribute wear over a much larger circumference and number of teeth than the crankshaft sprocket.
I might also note that my smaller original timing chain guide was broken in half at one of the mounting holes.  The one half that fell off was chew up quite a bit.
Here are pictures of a new and old one.  The old one has about 116,000 miles on it.
Well scratch the pictures. This forum is not accepting the jpg format at the moment.  I will have to review how to send pictures here.
SDK
« Reply #52 on: July 24, 2006, 20:32:00 »
SDK,
It's probably the picture size, cut it down to under 80kb.
« Reply #53 on: July 24, 2006, 22:25:46 »
Hey Naj,
How is this project coming along, while we're on the subject?
« Reply #54 on: July 25, 2006, 01:56:39 »
Hello, Joe,
Hey Naj,
Car is now with Rhodrich, after new chain and sprockets, engine running sweet as a 'nut':
http://index.php?topic=5377
He's been giving it Italian tune ups  :oops:
« Last Edit: July 25, 2006, 01:58:26 by naj »
Rhodrich
« Reply #55 on: July 26, 2006, 05:06:28 »
Indeed- 1700 miles driven in the past 2 weeks without any problems in my tours of the UK! (pic below in the car park at Stone Henge)
1965 230SL
