Author Topic: What's this for?  (Read 2275 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
What's this for?
« on: February 04, 2022, 14:04:26 »
In my tool kit (230sl) is the attached pictured tool.  I see no reference to it anywhere, nor does it show anywhere in any pictures etc in the tool kit write-up in the tech manual.  It is approximately 9 inches long, with an apparent part number 000 581 8501 (difficult to read)
What is it for?
jb
« Last Edit: February 04, 2022, 15:25:28 by John Betsch - "SADIE" »
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
Re: What's this for?
« Reply #1 on: February 04, 2022, 14:24:56 »
John,
It's not in my 280SL toolkit.
If you don't get an answer here, send the photo and make a call to https://www.samstagsales.com/
« Reply #2 on: February 04, 2022, 14:28:10 »
Does it fit the drain plugs on the oil pan, (manual) transmission or rear axle?
  • USA, NY, SOUTHOLD
« Reply #3 on: February 04, 2022, 14:54:16 »
Hard to see in the picture but one end is a "nut driver" socket with a number 10 on the shaft and the other end has a number 11 with the reverse ("nut")
Shaft also says Matador and Germany
looking at the numbers again, it could also be "9501"
jb
su8pack1
  • USA, PA, Barto
« Reply #4 on: February 04, 2022, 18:52:51 »
1984 300CD
1987 190E 2.6
1988 190D 2.5
  • USA, NY, SOUTHOLD
« Reply #5 on: February 04, 2022, 19:06:19 »
Thanks to the lead by su8pack1 and ebay, found the attached picture on the listing.  Now I know what it is, but now leads to the question of why it's in the tool kit, a question  which will never be answered.
merci
jb
« Reply #6 on: February 04, 2022, 19:42:54 »
Someone some day put it there not to forget to give it back to someone who left it in the car by accident...
The system does not recognize this part number.
« Reply #7 on: February 05, 2022, 15:07:26 »
It doesn't fit the nomenclature of the dealer service tools.  Dealer service tool usually start with chassis or engine of first use then the group 589.  For a W113 it would be 113 589 and for an M130 engine 130 589.  Usually an 01 in the last 2 digits denotes more than one part to the tool.  The complete tool number would end in 00 and it's parts would be 01, 02, 03 etc.
  • USA, NY, SOUTHOLD
« Reply #8 on: February 05, 2022, 15:17:54 »
this is what is on the center of the tool barrel other than a 10 at one end and 11 at the other
jb
WRe
« Reply #9 on: February 05, 2022, 15:48:12 »
nomenclature of service tools doesn't necessary start with model or engine type number. General tools had similar numbers mentioned here, see att. file.
The part numbers assigned to the tools have the following basic meaning:
Part number 115 589 02 23 00
or                  000 589 02 23 00
                     115                               model or unit type
                     000                               available in the stores
                            589                        construction group for tools
                                   02                   sequential number of the tool
                                        23              tool type
                                             00         complete tool
You can find a catalogue of special tools here: https://vdhflipbooks.de/books/KAT/KAT-SonderwerkzeugeBand1/#1.
For access these flipbooks see here: https://www.sl113.org/wiki/Documents/Start
...WRe
« Last Edit: February 05, 2022, 17:45:38 by WRe »
