Author Topic: Heater Lever Illumination  (Read 5715 times)
rjmarco
  • USA, CA, Alamo
« on: February 06, 2022, 18:44:10 »
Are all four heater levers supposed to be illuminated when you turn on the head lights or parking lights?  Here is a picture of my dash board.  Only three of the four are illuminated.  The blue lever is not.  My mechanic has told me that all my in dash bulbs are working.
Any suggestions for how to troubleshoot this issue?  I suspect that all four are supposed to be illuminated.  I'm having my Becker radio pulled for some work so this will present an opportunity to resolve the problem.
Thanks much!
Rich
Alamo, CA
BobH
Re: Heater Lever Illumination
« Reply #1 on: February 06, 2022, 19:19:03 »
As far as i know there are two bulbs, one to illuminate the levers on the left and another for the right, see picture borrowed from ebay
https://www.ebay.co.uk/itm/264979560096?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D6784353e921e43838b842d0558d49953%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D264979560096%26itm%3D264979560096%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Afdc74003-8780-11ec-b93a-aa52159bc983%7Cparentrq%3Ad075685017e0a6e5bb8141d2fff76ed5%7Ciid%3A1
The tech manual also describes the lights, it's strange that the bottom lever is illuminated but not the top, it says there's a clear tube that carries the light to the levels, perhaps it's dirty or slightly blocked?
https://www.sl113.org/wiki/Electrical/Levers
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #3 on: February 06, 2022, 20:08:56 »
There is only one light for the left levers.
If one is not illuminated the lever is not correct.
Conclusion, change for the correct blue level.
BobH
« Reply #4 on: February 06, 2022, 20:39:05 »
Just out of interest, what is an incorrect lever, are there different types?
UK delivered RHD
Blue soft top
Blue leather
rjmarco
  • USA, CA, Alamo
« Reply #5 on: February 06, 2022, 21:11:22 »
Thanks to all for the great comments.  I will study to photos carefully.  The levers installed in my car were purchased from Authentic Classics several years ago and are the "early type" for the 230SL and 250 SL.  I did retain the originals and will do a comparison.  I only changed out the originals since I was doing other in-dash work and thought it would be a good renewal.  I was concerned that the old levers would be brittle after 50 years.
Rich
Alamo, CA
BobH
UK delivered RHD
Blue soft top
Blue leather
« Reply #7 on: February 06, 2022, 22:14:40 »
Yes, both sets of levers allow for illumination.
The light does come through on the cars with the rubberized outer piece. The early levers are clear all the way through. The later style are to remove the sharp edges. This happened at VIN ending with 2979 on the 250 SL.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #8 on: February 06, 2022, 22:43:33 »
Are all four heater levers supposed to be illuminated when you turn on the head lights or parking lights?  Here is a picture of my dash board.  Only three of the four are illuminated.  The blue lever is not.  My mechanic has told me that all my in dash bulbs are working. Any suggestions for how to troubleshoot this issue?  I suspect that all four are supposed to be illuminated.  I'm having my Becker radio pulled for some work so this will present an opportunity to resolve the problem. Thanks much!
You've got the correct levers for a 65 230SL. The early levers aren't very bright with the lights on - if your bottom left (red) lever is lit, you can bet the upper left (blue) one is lit too because they use the same bulb. It's just not bright enough to notice unless you're driving at night and even then it's not very noticeable. I've attached a picture of my heater levers with my headlights on. You have to look real close to see that the blue one is illuminated..
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #9 on: February 06, 2022, 23:12:06 »
sorry about that..here's a couple of representative photos (just figured out how to turn off the flasher on my cel phone).
rjmarco
  • USA, CA, Alamo
« Reply #10 on: February 07, 2022, 00:35:02 »
Thanks, Charles.  I'll give this test a try after dark while inside the garage to see if I can see any illumination on the blue lever.  Appreciate you sharing your example.  Rich
Rich
Alamo, CA
rjmarco
  • USA, CA, Alamo
« Reply #11 on: February 07, 2022, 03:24:44 »
Hi, Charles.
Here is my test result in the attached photo.  The light is clearly on behind the blue lever but it is only faintly illuminated compared to the others which are quite bright.  I think this matches what you observed with your car.  Thanks again for the suggestion.
Rich
Rich
Alamo, CA
lreppond
  • USA, CA, San Leandro
« Reply #12 on: February 07, 2022, 16:25:42 »
I recently had my entire heater control module repaired including the replacement of the two cylinders that hold a bulb in each.  Over the years, the plastic cylinders had become fairly cloudy and I’m thinking that may have happened to yours as well.  That condition could explain why the upper blue is not more brightly illuminated.  All four of mine are quite bright including the upper blue lever.
I believe that Katie, Merc_Girl, recently had these cylinder replaced in her 230.  I’d contact her to see if there was the same kind of improvement.
Full disclosure: my car is a 71 and uses a slightly different set of levers.
« Last Edit: February 07, 2022, 16:56:12 by lreppond »
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
BobH
« Reply #13 on: February 07, 2022, 17:52:47 »
I don't often drive my 230 at night, so i didn't notice, but i've just checked and the top left blue lever is much dimmer than the other three, i wonder if it's to do with the colour, perhaps it's denser, but i can't imagine why it would make such a difference, perhaps lots of cars suffer this.  It's the same bulb and bulb holder that illuminates the bottom left and that one's bright, so makes no sense
UK delivered RHD
Blue soft top
Blue leather
sandcrab59
  • USA, MA, Lunenburg
« Reply #14 on: February 07, 2022, 21:45:57 »
Has anyone replaced that center bulb with an LED bulb?
If so which one and where to purchase one.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
BobH
« Reply #15 on: February 07, 2022, 23:40:54 »
I haven't changed mine, but i've read that they are BA7s 12V 2W, looks like these are a replacement, probably widely available, but best check with the vendor that they are a direct replacement
https://www.superbrightleds.com/moreinfo/miniature-and-subminiature-bulbs/ba7s-led-bulb-1-led-ba7s-retrofit-car/10/
UK delivered RHD
Blue soft top
Blue leather
clunker
  • USA, NJ, Chatham
« Reply #16 on: September 10, 2024, 17:26:53 »
Not looking to revive/start a whole thread, but I have added some pictures/directions in the technical manual under https://www.sl113.org/wiki/Electrical/Levers on the heater lever lighting bulb replacement.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
Brennie
« Reply #17 on: October 02, 2024, 14:44:45 »
Hi..
Just a quick thing if anyone is still looking at this old post…
While fiddling with my new radio…this fell out/down…I know what it is and ..it pushes back up..but because the plastic by the top screw is broken. It won’t stay put..the installed radio kinda holds it in place but,it’s not ideal….basically,am I screwed? Are these available and how would I fix it? Maybe an epoxy glue?..
Vander
  • USA, OH, Columbus
« Reply #18 on: October 02, 2024, 15:23:08 »
I have a W108 here now that had the exact same problem, and the black piece was epoxy glued. It did not hold up once you start operating the levers, so I would advise against it. We are sourcing a good used black plastic cap then will re-assemble and install.
Brennie
« Reply #19 on: October 02, 2024, 16:24:51 »
Thank you…
That’s what I thought …but,not what I wanted to hear…so..the search begins….what a nuisance..
Well,Vander,if you happen to find two…I’d be most grateful for a nod…
B
BobH
« Reply #20 on: October 02, 2024, 16:52:35 »
These do crop up time to time on auction sites, or they're available new from most of the usual suppliers, at a price!  Not sure if you can just buy the component parts though
https://www.niemoeller.de/en/w113/w113/B042/830/d83220a-lighting-heating-control-system-w108-113#:~:text=We%20offer%20Lighting,%20heating%20control%20system%20W108/113%20for%20your%20Mercedes
UK delivered RHD
Blue soft top
Blue leather
DavidAPease
  • USA, CA, Chico
« Reply #21 on: October 02, 2024, 19:58:05 »
For full members, there is a section in the Technical Manual with STL files for 3D printing parts.  Dirk Balter has contributed files for the parts you appear to be referring to:
   https://www.sl113.org/wiki/Restricted/3D-Printed-Parts
Don't worry if you don't have a 3D printer, there are many services that you can email an STL file to and for a very reasonable price (much less than a Mercedes replacement part) get back the 3d-printed part.  (JLCPCB (jlcpcb.com)is the company I've used most recently, but there are many others.)
          -David
-David Pease
Brennie
« Reply #22 on: October 02, 2024, 20:17:55 »
Absolutely wonderful.. exactly what’s needed… I’m going to check this out in the morning… now to find someone in the UK that can do the job…
Thank you David..
Brennie
« Reply #23 on: October 02, 2024, 20:23:05 »
Ok… that is not as simple as it might be…
Clicked “download “ and all I got was this message… something wrong somewhere??
DavidAPease
  • USA, CA, Chico
« Reply #24 on: October 02, 2024, 20:35:54 »
Brennie,
Did you click the STL file name below the drawing for the piece you wanted?  I just did that, and the STL file was downloaded to my Downloads folder.
Alternatively, I can right click on the STL file name and choose "Save Link As...", then I can choose where to download it and what to name it.  (I am using FireFox, but I think all of the browsers should work pretty much the same).  (I just tried it on the Chromium browser, and it worked exactly the same.)
           -David
-David Pease
