Author Topic: Hirschmann Original Antenna for 280SL  (Read 5513 times)
Damien280sl
  • United Kingdom, England, Whitehead, Carrickfergus
« on: February 09, 2022, 15:01:55 »
Hello All,
I need an antenna for my 280SL (Dec 1970). I would prefer an original Hirschmann one if possible. I believe the model reference is AUTA 6000.
If you have one for sale or know where I can get one, please let me know.
I'm located in Northern Ireland so I would prefer to buy one from somewhere local, but I will consider one from any country.
Damien
SEB
  • Germany, Berlin, Berlin
Re: Hirschmann Original Antenna for 280SL
« Reply #1 on: February 09, 2022, 16:50:11 »
Hello Damien,
you should find a lot of offers with this Hirschmann Antanna AUTA 6000 on EBay. At least on the German sites you can find many.
Best wishes!
Sebastian
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
Damien280sl
« Reply #2 on: February 09, 2022, 22:06:24 »
Hello Sebastian,
Thank you for your advice.
I understand that there are variations of the AUTA 6000 to suit different cars. Do you know the reference number I should search for?
Thanks again for your help.
Kind regards,
Damien
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #3 on: February 10, 2022, 08:12:24 »
Hello Sebastian,
Kind regards,
Damien
Any 6000 model will fit. Correct one was F58 AFAIK. Difference between them was in the lenght of the pole and attached mounting hardware.
See attached pics how my original one sits on its original positin.
1964 230SL
Damien280sl
« Reply #4 on: February 10, 2022, 09:03:31 »
Helo Sead,
Thank you for the information, it's very helpful.
Kind regards,
Damien
AndrewB
  • , Channel Islands, Forest
« Reply #5 on: February 10, 2022, 17:55:42 »
Hi Damien
Also worth trying Mike Seer at Chrome London, he is London (UK) based and has stock - at present it appears to me to be very difficult getting parts from outside the UK
https://www.chromelondon.com/hirschmann-electric-chrome-wing-aerial---universal-1280-p.asp
Regards
Andrew
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
gordon
  • United Kingdom, England, Burntwood
« Reply #6 on: February 10, 2022, 18:13:59 »
Chrome London also sells a kit to convert Becker Europa radio to blue tooth hands free etc, about £200 . It would still remain single Chanel.
sandcrab59
  • USA, MA, Lunenburg
« Reply #7 on: February 10, 2022, 21:58:17 »
I ordered one.
I hope it comes with complete wires to radio and every thing else.
Cannot tell from the description.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
AndrewB
« Reply #8 on: February 11, 2022, 09:05:27 »
I have the Chrome London Bluetooth kit. Plugs into the Becker radio via the DIN plug, and I find it works well.
1987 500SL
pagoda113
  • United Kingdom, England, Surrey
« Last Edit: February 11, 2022, 09:58:18 by pagoda113 »
Damien280sl
« Reply #10 on: February 11, 2022, 11:49:05 »
Hi All,
Thank you for the advice.
Pagoda113, thank you for the link. I have ordered one from them.
I would prefer an original one, but the 2050 will do until I find one.
The list of things I need is getting smaller!
Kind regards,
Damien
sandcrab59
« Reply #11 on: February 14, 2022, 14:29:26 »
When I found out about this antenna, I ordered it.
But until I found out about it, I was going to put in an antenna from one of my many antennas
I have from my 126 chasis. 300sd. (1981 to 1985)
Since it is hidden no one will ever know what antenna you have.
It will work.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
pagoda113
« Reply #12 on: February 16, 2022, 09:55:25 »
Well mine have just arrived and so far pleased with them. For the money cant argue over them.
sandcrab59
« Reply #13 on: February 18, 2022, 13:09:22 »
Received mine also. But I have a concern.
There is a green wire that I do not know where it goes on the back of the radio.
There is no place for that wire.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
Pastarnac
  • USA, MA, Rehoboth
« Reply #14 on: February 18, 2022, 19:14:04 »
There were manual and automatic antennas.
The automatic ones you recognize after the aluminum body and external ears that secures the antenna to the chassis.
There were 2 models that fit:
Auta6000F58
Auta6000F108
Expect to pay +$600 for an automatic antenna
Electrically speaking the output cables are:
- Ground
- +12V going thru a fuse.
- +12V output trigger signal from the back of the radio. That is usually a spade connector
- RF wire; this one is easy to recognize
« Last Edit: February 18, 2022, 19:29:55 by Pastarnac »
