Author Topic: Screen wash pipe route  (Read 1505 times)
gordon
  • United Kingdom, England, Burntwood
« on: February 10, 2022, 18:04:39 »
Right hand drive 230 SL, I'd like to reinstate the screen wash delivery pipe which was removed some time ago, From under the cowl I assume that it goes through the hole into the air box. Does it then go inside the car then re emerge in the vicinity of the wiper motor to go to the pump?
There is a hole below the wiper motor that I've put the bonnet release cable through, is this correct?  Any guidance would be appreciated
Re: Screen wash pipe route
« Reply #1 on: February 10, 2022, 19:24:10 »
Search is usually helpful: https://www.sl113.org/forums/index.php?topic=28761.msg207910#msg207910
Multiple links under the link I provided.
gordon
« Reply #2 on: February 10, 2022, 21:13:34 »
All sorted, thanks for your guidance
