Author Topic: Intake manifold  (Read 3048 times)
Michael Foster
  • USA, FL, Doral
Intake manifold
« on: February 10, 2022, 20:57:20 »
Hello, I have removed my intake manifold and found lots of crud inside. It seems that the air orifices that introduce air from the idle air controller to each of the 6 intake tubes are pugged or severely restricted. There seems to be a plug over each intake tube filled with lead, aluminum or other softer metal that seems to be access to these orifices.
How do I go about cleaning the manifold and these orifices?
MF
Re: Intake manifold
« Reply #1 on: February 10, 2022, 22:05:59 »
I've never had any sort of luck trying to remove those soft plugs so I would leave them be. Carb cleaner or similar would be your better choice. If you know someone who has a parts cleaner they do a nice job.
Michael Foster
  • USA, FL, Doral
Re: Intake manifold
« Reply #2 on: February 10, 2022, 23:37:35 »
Thanks much Doctor.
Here in Panamá a parts cleaner is a guy out back with a brush.
I have it soaking in diesel, and the stuff is coming loose slowly.
My concern is poking something into the orifice that may make it too big.
MF
Re: Intake manifold
« Reply #3 on: February 11, 2022, 06:47:21 »
Take it to an automotive machine shop. Most of those places will have a machine that's kind of like a large dish washer. This machine uses hot water or steam to clean off grease and it will remove all of that crud without damaging anything.
Re: Intake manifold
« Reply #4 on: February 11, 2022, 10:11:33 »
Better still find somewhere locally that has an unltrasonic bath big enough. That will yield perfect results.
Michael Foster
  • USA, FL, Doral
Re: Intake manifold
« Reply #5 on: February 11, 2022, 12:18:18 »
Thank you for the information.
I used to have a steam cleaner for my heavy equipment, I am Shure I can find someone with one.
Re: Intake manifold
« Reply #6 on: February 17, 2022, 19:57:20 »
A steam cleaner will be unlikely to yield great a result but it's worth a shot.
