Author Topic: Car lifts for storage  (Read 6412 times)
john.mancini
  • USA, FL, Nokomis
« on: February 17, 2022, 02:41:23 »
I am looking, preferably,  for a 4 post car lift system, in order to store another car in my garage. As I searched the older threads on this topic, I found that there are some new lifts on the market that were not available back when these posts appeared. Has anyone had any experience with the Triumph NSS-8SQ? This is a four post, 8,000 lb, compact lift that will nicely fit in my garage. Perfect for older cars like our SL's and air cooled Porsches. The other is the BendPak Autostacker. Very pricey, but very compact. Any other suggestions?
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Pinder
  • USA, NJ, Edison
Re: Car lifts for storage
« Reply #1 on: February 17, 2022, 02:50:53 »
No. But its its on my wish list so I am in interested in the responses.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #2 on: February 17, 2022, 03:10:40 »
I use a two post hoist with wheel pickup to avoid suspension hang and I store car on it.  It has a relatively low profile hydraulic lift, made by a company called EAE and carries 4500kg or just under 10,000lb. Purchased in Australia but originally saw it in USA. I can attach jack pads if i want to use it that way.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Jordan
  • Canada, ON, Jordan
« Reply #3 on: February 17, 2022, 03:18:40 »
Hey John, I have a 4 post with very similar specs to the one you are looking at but with about 2-ft longer ramps.
https://liftsuperstore.com/product/quatro-stacker-standard-8000-lb-3-6t/
I like the 4 post because it is mobile so I can move it, even with a vehicle on it (mine is in a 36x32-ft garage/barn with 12-ft ceiling and 6-in concrete reinforced floor).  I also get to stand up when I'm working under the car.
Marcus
66 230SL  Euro 4 speed
Vander
  • USA, OH, Columbus
« Reply #4 on: February 17, 2022, 12:25:14 »
Bendpak is the best lift money can buy, think of it as the Mercedes-Benz of lifts.
However, if all you want to do is gain an extra parking spot at your residential garage then it is overkill.
I have both 2-post and 4-post Bendpak lifts and I use those as my workhorses. HD-9 is the 4 post model I have.
But when I wanted an extra parking spot I went with one of the cheap black Chinese lifts, and it has been great. 4 or 5 companies sell this same economy lift, they just slap their own sticker on it.
Check-out Bestbuyautoequipment.com
I've talked to a dozen lift manufacturers and dealers and their customer service was the best.
« Reply #5 on: February 17, 2022, 16:20:13 »
I'll throw in my 3 cents. I have a Backyard Buddy four post lift. Top notch item. I liked the way the locking mechanism is set up - using a square steel column at each corner with the lock notches cut into the beam, not welded in.
I purchased it while I was in Ohio and they were able to deliver it to me, as they are located in Warren Ohio, not so terribly far from where I was located at the time. When I moved to SoCal, I was able to take it apart and get it moved out here.
https://www.advantagelifts.com/collections/backyard-buddy
  • USA, WI, Mequon
« Reply #6 on: February 17, 2022, 16:45:13 »
That's a stretch, hardly the MB of lifts.  And, I own one, am happy with it, and would buy again, but it's no MB
« Reply #7 on: February 17, 2022, 17:23:06 »
I, too, have a BendPak 2-post lift.  While they do offer a host of interchangeable 60mm pad attachments to fit the arm ends, their website does not show the availability of wheel pickup attachments like Garry pictures.
Norm
  • USA, TX, Wimberley
« Reply #8 on: February 17, 2022, 17:44:48 »
I had the Bendpak 4 post and liked it.  The only change I had to make was to move my garage door opener from overhead to a side mount.  I would definitely purchase again if I felt the need.  a bigger garage is a nicer option. ;D
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
johnk
  • USA, OH, Avon
« Reply #9 on: February 17, 2022, 20:33:14 »
I was just about to buy the triumph lift until I decided to sell my Alfa. It is very reasonably priced and came highly recommended by people at a local at a local car parts distributor that owns several of them.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
john.mancini
  • USA, FL, Nokomis
« Reply #10 on: February 17, 2022, 21:07:04 »
Thanks so much guys. I don't think you can go wrong with either of the BendPak or the Triumph. Both get great reviews. The Triumph offers a shortened version of the NSS-8, called the NSS-8SQ Classic, for smaller sports cars. This may be perfect. Now to find an installer in the 34275 Florida area. Can anyone recommend an installer in this area?
John
98 911 cab
56 Ford F100
23 Z4M40i
Jordan
« Reply #11 on: February 17, 2022, 21:15:28 »
John, if you have someone that can help you should be able to put it together yourself.  It's not especially difficult.  I put mine together myself and just used a loader tractor to lift and position the ramps.
Marcus
Norm
« Reply #12 on: February 17, 2022, 21:16:57 »
When I ordered my Bendpak they provided an installer who delivered and installed the lift.
Maybe Triumph will do the same....
Norm
Norm
johnk
  • USA, OH, Avon
« Reply #13 on: February 17, 2022, 23:38:42 »
wherever its shipped to you need to be able to unload it from the truck.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #14 on: February 18, 2022, 00:03:34 »
When I ordered my BendPak lift Summit Racing called me to verify that there would be a forklift available for unloading at the delivery address.
john.mancini
  • USA, FL, Nokomis
« Reply #15 on: February 18, 2022, 01:29:57 »
I have plenty of bodies around who would enjoy putting the lift together, but no fork lift. I may take the easy way out and have an installer do the dirty work!!
John
98 911 cab
56 Ford F100
23 Z4M40i
specracer
  • USA, MA, Duxbury
« Reply #16 on: February 18, 2022, 09:52:24 »
My 2c, find an installer 1st, then see what brand(s) they represent. I have a fork lift, and above avg mechanical ability, but I still had all of our lifts installed (6 off shore 4 posts). Seeing the pros use their specialized tools, carts, and tricks, I was glad, each time, I chose that direction.
lowpad
  • USA, CT, New Preston
« Reply #17 on: February 19, 2022, 16:08:50 »
I just installed two Advantage lifts in my garage. I paid to have it installed, which I think is worth every cent.  Very happy with the result.
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
john.mancini
  • USA, FL, Nokomis
« Reply #18 on: February 20, 2022, 01:33:03 »
I just checked out the Advantage lifts. Looks like they are a great product.
John
98 911 cab
56 Ford F100
23 Z4M40i
mazmonza
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
« Reply #19 on: February 20, 2022, 20:18:07 »
I'm  pleased with my Twin Busch, worth a look
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
RobSirg
« Reply #20 on: February 21, 2022, 05:17:41 »
I've just added a single post stacker to my Car storage - that way I don't have a post impeding my car movement as the single post is against the wall.
In my last house I had a single post hoist/stacker with a chequer plate flooring which was fine (easy drive on and off) but I chose one with rails this time so I have under car access.
Rated to 2700kg's
Costs have halved in the last 10 years so these days it was under AU$6K plus installation.
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
johnk
  • USA, OH, Avon
« Reply #21 on: February 21, 2022, 12:34:37 »
I have garage envy!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #22 on: February 21, 2022, 12:53:38 »
I have garage envy!
Tell me about it...
johnk
  • USA, OH, Avon
« Reply #23 on: February 21, 2022, 16:39:47 »
I can’t help but think how much it would cost me to have a garage like Robsirg’s. Not just the cost of the garage and the cars inside it, but the two or three times I would have to spend on my wife to allow me to do it!!
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
  • USA, WI, Mequon
« Reply #24 on: February 21, 2022, 17:12:23 »
RobSirg
You and I have four of the same vintage cars, 190 SL, 250 SL, 911 and E-type, although I don't see the E in your list.
