Author Topic: Head light bulb and rear brake cylinder  (Read 4573 times)
« on: May 20, 2003, 17:46:03 »
113 Group:
Maude 1965 230 SL
I should have a coulple of headlights on hand.  Haynes manual describes the bulbs (have European type) as 45/40.  What does this mean and what should I ask for at the local auto shop?
I am replacing the rear brake cylinder $125.00 C (part from the local Mercedes dealer).  I am going to save the old one and put in a rebuild kit.  Is there any off the shelf rebuild kit that will fit?
Thank you,
Rupert
Re: Head light bulb and rear brake cylinder
« Reply #1 on: May 21, 2003, 05:06:37 »
Rupert,
The bulb base is type P45t aka R2 over the pond. You can fit the 45/40 watt tungsten bulbs or upgrade to halogen bulbs with the same base. I believe they are 55/50 watt or similar. The higher number is the full beam wattage while the lower is low beam.
The rear slave cylinders are 3/4 inch diameter. You may be able to buy just the rubbers at a brake specialist.
'Kloines Scheisserle'
