Author Topic: SL230 Late Thermo Time switch Pod  (Read 1988 times)
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« on: March 02, 2022, 13:25:20 »
Hi Guys A big thanks for your help in the past . Advise needed again my car is a 1967 SL 230 and therefore was not fitted with the extra Thermo switch . Please see photo my question is what should fix to the spare screw connection on the pod .
Thanks Les
dirkbalter
  • USA, CA, Corona
Re: SL230 Late Thermo Time switch Pod
« Reply #1 on: March 02, 2022, 19:42:00 »
My 66 230 has the thermo switch in the location you are showing. I didn’t know it was removed or relocated for 67.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Leester
  • USA, VA, Lorton
« Reply #2 on: March 03, 2022, 00:13:38 »
I suppose you could buy a plug - probably an Allen wrench type. But Dirk's got it, are you really sure your car didn't originally come with the TTS?
Lee Backus
1963 220SE Cabriolet
1985 500SEC
« Reply #3 on: March 03, 2022, 01:22:53 »
Yes, the empty hole is for a "thermo time switch" and not the additional "time switch" sensor used on the early 230SLs.  All pagodas use the "thermo time switch". Only the earliest versions 230SL used both the "time switch" and "thermo time switch".
gordon
  • United Kingdom, England, Burntwood
« Reply #4 on: March 03, 2022, 21:40:06 »
Mine is a  1965 230 SL  Attached please see a photo of mine with two terminals with pink to one and pink and blue to the other. ( Ignore the green wire which goes to ground to bypass my failed TTS)
Esmo
  • SL 230 1967
« Reply #5 on: March 04, 2022, 10:27:12 »
Thanks to all , the thermo time switch has been lost in the rebuild , just ordered from the SL shop . 001 545 92 24 .
