Author Topic: Gear Shifter and Shifter Gate  (Read 5898 times)
« on: March 13, 2022, 17:16:02 »
I have come across this post on the fb: https://www.facebook.com/photo?fbid=4879993515456780&set=gm.10158667595071381
Some folks there say this type of gate shifter, its gate and, perhaps gear box too were fitted in some US cars towards the end of Pagoda production.
Were they?
bogeyman
  • USA, NE, Omaha
Re: Gear Shifter and Shifter Gate
« Reply #1 on: March 13, 2022, 17:19:44 »
Not to my knowledge. I have a 350SL built in Nov '71 and it has the old style chrome shift gate. The R107s didn't change until sometime in '72 - long after the last W113 was built.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
« Reply #2 on: March 13, 2022, 17:44:47 »
That is what I thought. But some guys there claim they have seen several of them... I thought I had better ask.
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: March 13, 2022, 18:19:48 »
My 1971 has a R107 shifter knob - which the PO installed. Not original.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
cfm65@me.com
  • Cape Town, South Africa
« Reply #4 on: December 22, 2022, 18:27:55 »
I think the Pagoda shifter works the other way round. Park is all the way back, if I remember correctly.
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #5 on: December 22, 2022, 22:11:20 »
Correct, the pattern is reversed, so I don't think it's possible without a w107 (or other) transmission.
I have a FB account, but don't use it for anything in my life that requires factual information.
zak
  • USA, NJ, Bernardsville
« Reply #6 on: January 04, 2023, 21:46:50 »
The wood tray incorporating the shifter was nicely done and almost looks stock.
It looks like the shifter is raised higher than on the original setup too.
Would a later model MB trans easily fit a pagoda engine ?
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« Reply #7 on: January 05, 2023, 13:27:10 »
When I obtained my W113 it was fitted with a late W108 motor and automatic gear box.  If I recall correctly, to retro fit the original motor and automatic gear box, the propshaft tunnel had to be reshaped (as the W108 gear box was wider and the tunnel had been widened), the gear lever gate opening in the tunnel had to be slightly moved forward and the propshaft had to be replaced.
The late model W108 automatic gear box would fit the W113 motor itself without any complications, the challenge lies the other necessary modifications.
Klaus
