Author Topic: Seat tracks  (Read 1651 times)
dirkbalter
  • USA, CA, Corona
Seat tracks
« on: March 14, 2022, 23:04:35 »
Has anybody successfully disassembled and reassembled the seat tracks? (How?)
Mine are not moving as easy as I would like it. It appears that the track component are crimped and riveted together?
Thank you
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pinder
  • USA, NJ, Edison
Re: Seat tracks
« Reply #1 on: March 15, 2022, 01:37:05 »
Dirk. Mine were also stuck but if you use WD40 or any lubricant it should free up after forcing it back and forth. no need to disassembly.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
roymil
Re: Seat tracks
« Reply #2 on: March 17, 2022, 21:57:42 »
Hello, My seat slide rails had become hard to move too and when they did slide it wasn't a smooth ride at all.  I chose not to attempt complete disassembly because they really were't broken, just very dirty inside.   I ended up soaking them in a slightly diluted degreaser (purple power) for about a week. I took them out a few times to blast out the inside with high pressure water from every angle.   At the end, all of the old hardened grease and various dirt/grit contaminants were gone and I could slide them by hand easily.   I let them bake out in the hot sun on my driveway until completely dry and then added small amount of wheel bearing grease to the inside of the slides and worked them back and forth until it was distributed and smooth.   I just looked and see I might have added too much grease and so I'll go clean that off.  It shouldn't need much, just enough to coat the ball bearings.   good luck! - Mark
Mark Miller
1968 280SL
Re: Seat tracks
« Reply #3 on: March 17, 2022, 21:59:09 »
Brake cleaner and patience - that is what I used on mine. Then lubrication with ordinary bearing grease.
dirkbalter
  • USA, CA, Corona
Re: Seat tracks
« Reply #4 on: March 17, 2022, 22:12:56 »
Thank you.
I will keep them assembled as well. Soaking in cleaner right now.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pinder
  • USA, NJ, Edison
Re: Seat tracks
« Reply #5 on: March 17, 2022, 23:29:12 »
Yes. I used all sorts of stuff including sea foam, trans fluid. they will free up like new.
