Author Topic: Removing from Winter  (Read 1498 times)
StevenF
  • USA, NY, Merrick
« on: April 06, 2022, 19:09:43 »
Dear Members
Separate of inflating the tires, changing oil and filter and fresh gas--what else would you recommend after a long winter?
Best Regards
Steven
1971 280sl
Red Metallic
Bamboo MB Tex
MikeSimon
  • USA, OH, North Royalton
Re: Removing from Winter
« Reply #1 on: April 06, 2022, 22:09:22 »
Well, Steven, for one thing, you should have changed the oil BEFORE storing your car. You need to get rid of all contaminants and moisture in the oil before letting the car sit for the winter months.
I hope you at least put some sort of fuel stabilizer in the car and filled the tank up to prevent rust forming on the inside.
There is actually more to do before putting in storage than when pulling the car out.
I also inflate the tires to 50-55 PSI to prevent flat spots from sitting.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: April 07, 2022, 03:16:46 »
Yes, best to change oil and filter before winter storage.
  • USA, WI, Mequon
« Reply #3 on: April 07, 2022, 14:03:17 »
I agree on pre-storage oil change, but don't lose sleep over it, just do it going forward.  Otherwise, assuming things were fine before storage, just start her up and go...gently.  Let her get good and warmed and loosened up, all fluids well circulated and warm before driving more aggressively or shutting down.
 Before changing your oil, get it good and hot and circulated, as described above.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #4 on: April 07, 2022, 23:26:29 »
Now is a good time to wash your car - pull the carpets and look in the corners for any evidence of staining from water.  Vacuum and wipe down the upholstry with a material appropriate elixir, clean your windows - wipe down the windshield wipers and start the engine and once warm stick your head under the hodd to see if there are any funny smells or leaking fluids.     Then you can look at the Mercedes prescribed maintenance schedule and check a few items like fluids on the list just for fun.
I don't put my car away for the winter but I do the above on the oil change day anyways.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
