Author Topic: Greasing Fitting  (Read 3267 times)
Greasing Fitting
« on: April 07, 2022, 14:15:04 »
I thought I would share quickly... If you all know it already - sorry.
I bought something like this (not exactly this one, but could not find exactly the one I bought):  https://allegro.pl/oferta/koncowka-smarownicy-zatrzaskowa-bez-trzymania-m10-7764270676
A true blessing! Greasing time of the usual 15 points - 1/3rd of what it was before....
Jordan
  • Canada, ON, Jordan
Re: Greasing Fitting
« Reply #1 on: April 07, 2022, 15:38:36 »
And how does this save you time?  Not understanding.
Marcus
66 230SL  Euro 4 speed
« Reply #2 on: April 07, 2022, 16:21:47 »
Maybe it was just me, but 2/3 of the greasing time I used to spend on snapping on and snapping off the greaser fitting. Now it takes 0.5 seconds.
roymil
« Reply #3 on: April 07, 2022, 16:26:07 »
Yes Pawel, I sure agree that locking grease zerk fitting makes it easier and quicker since you don't have to worry about it falling off when slightly off alignment and then you have less grease escape messes.  I found one that also had an adjustable angle fitting,  for hard to reach spots.  That was a blessing, but the best investment I made was in a cordless power grease gun.   When resurrecting my pagoda some of the 30 yr old grease had become so thick a hand pump just couldn't push it out.   The power gun was able to move all the old sludge out easily with no effort and bad words out of me.
This is the one i bought, but there are others out there too.
https://www.dewalt.com/product/dcgg571b/20v-max-grease-gun-tool-only?tid=579251
Mark Miller
1968 280SL
« Reply #4 on: April 07, 2022, 16:32:20 »
I was curious about the power grease gun and if it would blow out old grease like in the door hinges. Lubing those is not easy even with a heat gun to warm it up. The locking grease tip would not help with that, but not having to pump and hold the needle point grease fitting at the same time would allow more control.
I also have the locking tip and is wonderful.
roymil
« Reply #5 on: April 07, 2022, 16:42:28 »
Hmm, I wasn't aware of needing to grease door hinges but I do have a creaking sound in my door.   Can you describe how, or point to instructions?  thanks much, Mark
Mark Miller
1968 280SL
« Reply #6 on: April 07, 2022, 17:51:45 »
It looks like a decent one! I use mine once a year practically so I manage investment... but I got a nice pneumatic Hazet piece.
« Reply #7 on: April 07, 2022, 19:29:12 »
Yes, discussed on the forum many times, e.g.:
https://www.sl113.org/forums/index.php?topic=25626.msg183464#msg183464
https://www.sl113.org/forums/index.php?topic=10328.msg68709#msg68709
