Author Topic: Fixed my seat with a pool noodle  (Read 2428 times)
Rick Katucki
  • USA, ID, Eagle
« on: April 16, 2022, 22:17:53 »
I remembered seeing a post a while back that outlined using a foam pool noodle to firm up a sagging seat.  Well, I tried it and it works.  Easy too. I removed the seat from the car. Cut the noodle to fit and inserted it between the springs and reinstalled the seat.  Probably the easiest repair procedure I have ever preformed on my Pagoda and seat feels firm. No more leaning into the door while I'm driving.      Original posting : https://www.sl113.org/forums/index.php?topic=21723.msg154766#msg154766
Rick Katucki
64 230SL
Manual
Idaho, USA
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
Re: Fixed my seat with a pool noodle
« Reply #1 on: April 18, 2022, 09:18:40 »
yep... great tip. I did the same , after 56 years my drivers seat was a bit soggy (this German stuff just doesn't last! ) and all sorted now. Also the cheapest job ever done on the pagoda!
Pinder
  • USA, NJ, Edison
« Reply #2 on: April 27, 2022, 00:09:59 »
Great idea.  I also use the filling from inside of old comforters to puff up seats and worked especially well on head rests.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #3 on: April 27, 2022, 07:25:30 »
This is how i did mine.
Makes a huge difference.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Bill
  • USA, CA, Fair Oaks
« Reply #4 on: May 20, 2022, 23:58:44 »
Did you replace the horse hair cushion too or continue to use the original?
« Reply #5 on: May 21, 2022, 08:25:22 »
I replaced the horse hair.  I noted recently Jon Bernadi’s recent post on the use of stainless steel ties on the springs looks a fantastic additional thing that i will do when i take out me seats next. I dont think you can go too hard as there will always be give just by the nature of the seating spring set up. So i would suggest both. The noodles hold the front of the seat up and the ties would firm up the squab.
