Author Topic: safety catch door handles  (Read 1703 times)
tourguidedocent
« on: April 27, 2022, 15:10:09 »
How do you repair the safety catch on door handles?  Do I need to replace entire handles?
Re: safety catch door handles
« Reply #1 on: April 28, 2022, 03:18:19 »
Not sure what you mean by "safety catch".
tourguidedocent
« Reply #2 on: April 28, 2022, 13:11:16 »
when one partially pushes the door handle button from the outside, the door doesn't fully unlatch.  It's a partial unlatch, for safety reasons.  In my car the safety latch only appears to work on the driver's side, but not the passenger side.  Wondering if/how to repair this.
Jordan
  • Canada, ON, Jordan
« Reply #3 on: April 28, 2022, 19:29:37 »
Have you done anything to your door latch on the B pillar recently?
It could be that the latch has moved up slightly so the first notch under the latch is not catching.  Look under the latch and you should see 2 notches, the first one catches the door as you start to close it (your safety catch) while the second notch keeps the door closed fully.  You should hear 2 clicks as you close the door.  I suspect either the B pillar latch has moved or the one on the door itself.
Marcus
66 230SL  Euro 4 speed
