Become a Full Member and enjoy Pagoda Notes and Pagoda World — and join our Emergency Contact List!
thanks for your answer. I will pull the plugs tomorrow and see. When I do the split linkage if I increase the air slightly idle increases about 50 rpm then dies.If I increase the FIP it does the same thing so I think this is right. It only backfires when I accelerate to about 20 mph and it doesn't do it all the time seems to happen onlky in the first 15 minutes of driving.The WRD seems to be working fine as the idle drops and air shuts off unless maybe water is getting past.I read maybe I should put sealant under the WRD thermostsat
Bracurrie thanks for your reply but I can't read the page you sent it's there but too light to read
Sorry I don't know how to tell what PDF reader I have it's an HP laptop.How do i make the warm up richer. I tried adding oval shims but it still did it. I also added shims under the can thinking that it would make it richer for all ranges but it still pops on acceration around 20 mph.
