Author Topic: Cracked oil filter canister  (Read 5049 times)
Nickw
« on: May 02, 2022, 18:36:46 »
hey everyone I crack my Oil Filter Canister a little do you think it will have a affect to the oil if it’s a little cracked? Or would
I have to get a new one?
Re: Cracked oil filter canister
« Reply #1 on: May 02, 2022, 18:59:58 »
Hi Nick,
In the perfect world, you are going to want to replace it.
However, as a stop-gap measure, you may be able to seal up the crack with epoxy or JB-Weld. You are going to need to thoroughly degrease and clean the area so that the material will stick.
There's a product called Hy-Poxy H-450 Alumabond epoxy made specifically for such things. It's worth a try.
I think cleanliness will be the key in making this work.
« Reply #2 on: May 02, 2022, 19:07:22 »
That canister is scrap now and not easily repairable. Looks like someone installed two O-rings in there which will make them crack every time.
john.mancini
  • USA, FL, Nokomis
« Reply #3 on: May 02, 2022, 20:17:08 »
Replace it as soon as you can.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #4 on: May 02, 2022, 22:44:43 »
Or spend a few bucks for a 190SL group Spin-on Oil Filter Adapter.  I love mine, and no o-rings or center bolt to leak like a sieve during oil changes.  Quick and easy and a lot cleaner.
However, it's not original and would probably lose you a few points in a concours d'elegance.
My favorite vintage car phrase applies, I'm a purist, but not a masochist.
Tom Kizer
thomas wright
« Reply #5 on: May 03, 2022, 19:59:08 »
As a stop-gap until you decide to replace it  I would use a large diameter hose clip, Jubilee type, as this will also hold the fractured piece in place.
Suggest putting the clip on the canister first and then offering up to the engine .
Good luck.
Kevkeller
  • USA, HI, Honolulu
« Reply #6 on: May 03, 2022, 21:37:15 »
Can you tell what it’s made of?  Maybe a welder/machine shop can do a repair.
1970 280 SL
« Reply #7 on: May 04, 2022, 02:04:02 »
It's die cast aluminum and it's not worth trying to fix. The spin on filter is less than half the size of the cartridge filter and seems small for an engine with 6 liters of oil.
I have a spare casting if you need one. You will need to get seals for it.
dirkbalter
  • USA, CA, Corona
« Reply #8 on: May 04, 2022, 03:33:52 »
My engine rebuilder advised me that it is important that the housing has a good lower seal as it is almost impossible to change it.
He actually gave my a housing back with the statement that it is "junk"
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #9 on: May 04, 2022, 03:41:15 »
Dirk - I recall replacing the lower seal at least once, it is do-able. As I recall, I had to remove a sort of 'hat' at the bottom with a pick, then I could swap the seal, then press the 'hat' back on. That's my recollection anyway, probably around 15 years ago I did this.
dirkbalter
  • USA, CA, Corona
« Reply #10 on: May 04, 2022, 03:48:16 »
Cees, I have no done or attempted to do it. Metric gave me a new one and did not want to deal with that.
Let me change my statement from "almost impossible" to "tricky". lol.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #11 on: May 04, 2022, 03:54:53 »
The bottom seal is replaceable. The metal retainer ring is pressed on and can be removed. The metal retainer ring is missing on the filter in your picture. Buy the canister from Dan. Maybe he will install the new seals for you?
« Reply #12 on: May 04, 2022, 06:42:21 »
The hat part is available as a separate part. The trick is to use a new one because they don't seem to be reusable.
WRe
« Reply #13 on: May 04, 2022, 07:37:31 »
the bottom seal can be replaced easily by pushing the metal retainer ring from outside of the canister because there is a tiny rim where you can put a screwdriver in place.
...WRe
TJMart
  • USA, NC, Matthews
« Reply #14 on: May 04, 2022, 19:36:58 »
It would be better to replace it. Here is a link to a new one. In case you damage the "hat" when removing or replacing it they also sell it but I could not locate it. Give George a call.
https://www.authenticclassics.com/Mercedes-Engine-Oil-Filter-Housing-p/auth-003520.htm
Tony
Tony
1970 280SL, 4 Speed
Jordan
  • Canada, ON, Jordan
« Reply #15 on: May 04, 2022, 21:00:32 »
Hey Dan, the early 911's use a spin on filter and they use 9 litres of oil.  You know the old saying, "Its not how big it is, it's how you use it."  ;)
Marcus
66 230SL  Euro 4 speed
Nickw
« Reply #16 on: May 08, 2022, 04:00:41 »
I’m sorry for the late response I been very busy’ but I want to say thank you guys for all you response’s and help guys god bless yous!
Ps I’m not to good about leaving massages and post so I hope I’m doing this right 😋
Thanks…
MikeSimon
  • USA, OH, North Royalton
« Reply #17 on: May 08, 2022, 21:11:10 »
Do not want to argue with that, but my 1971 914-6 with a 1974 2.7 flat six has a 16 quart oil capacity.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #18 on: August 02, 2022, 15:27:54 »
I know how, I just can't remember why.
