Author Topic: Re-Key Trunk Lock Tumbler  (Read 1756 times)
Bill Sgro
  • USA, FL, Bradenton
« on: May 03, 2022, 00:14:44 »
How would I change the tumbler in my trunk lock to fit a new key?
It is the two-sided late 280SL (build date 4/1970) key.  It should fit the ignition, door, glove box, trunk and gas cap.
I guess I could take it to a locksmith.
1970 300SEL 3.5
lreppond
  • USA, CA, San Leandro
Re: Re-Key Trunk Lock Tumbler
« Reply #1 on: May 03, 2022, 01:45:03 »
The removal is shown in the tech manual.  It’s very straightforward.  Here’s the link:
https://www.sl113.org/wiki/ChassisBody/TrunkLock
If you are matching it to the other locks on your car, you’ll need wafers that are Ymos HF style. (I’m assuming you have an HF key way. Look on your build card in case you don’t remember.) They are not readily available and you may have to do some searching.  I doubt your average locksmith will have them.
Good luck and report back on your progress.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
