Author Topic: Aligning ignition barrel  (Read 1645 times)
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
« on: May 03, 2022, 21:31:28 »
So today I thought I would try to get my ignition centered.  I removed the bolts to drop the steering column but I can't seem to move it.  Is there another bolt somewhere?   I mean, i can move it a bit but is not enough.  Also, the steering column seems the be in the right place on the dash, so is it possible the ignition barrel is what needs to be adjusted?  And anyone have a trick to getting  the bracket nut off the back of the speedometer?
Lori
1968 280SL (US)
Kevkeller
  • USA, HI, Honolulu
Re: Aligning ignition barrel
« Reply #1 on: May 03, 2022, 21:40:45 »
It’s been years since I removed my instruments but I think I laid on my back and reached up by hand to remove the nut on the speedometer.
I have no idea why your key barrel won’t line up. I thought it’d be in a fixed position.  It’s always been misaligned?
1970 280 SL
« Reply #2 on: May 03, 2022, 21:49:31 »
I suggest to take out the left chromed aircover and airduct.
Via the hole you then you can loosen the nuts one by one of all instruments.
Lorsar
  • 1968 280SL (US)
« Reply #3 on: May 03, 2022, 22:00:08 »
Not sure you can see it  in the pictures but I have the left chrome air duct out and I was able to remove the bracket nuts from the tach and center unit, just not the speedo.
Yes, it's always been off center since got it
Lori
1968 280SL (US)
dirkbalter
  • USA, CA, Corona
« Reply #4 on: May 04, 2022, 01:39:30 »
The ignition unit is clamped with a screw to the steering column. Once you get the center out, you should be able to see and access the screw without removing the speedo.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Lorsar
  • 1968 280SL (US)
« Reply #5 on: May 06, 2022, 01:52:08 »
Thanks Dirk, you got me further along.  Still wouldn't  move much so I resigned myself to trying to get the speedometer out.  Taking turns with my husband, we finally got that nut loose. The tips of our fingers are still numb.  Turns out there is a bracket on the other side of the ignition.  It wasn't really seated in there at all.  With much twisting and prying, we got it centered but a bit angled on the right.   It's supposed to be straight, right?
« Last Edit: May 06, 2022, 02:22:25 by Lorsar »
Lori
1968 280SL (US)
dirkbalter
  • USA, CA, Corona
« Reply #6 on: May 06, 2022, 02:47:29 »
Centering looks good to me. It’s hard to tell from the picture but it seems it could come out a bit more?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #7 on: May 06, 2022, 13:07:49 »
Wow Lori great job looks a whole lot better than it was!
Now give your fingers a rest! 😉
