Hi Dirk,
I appreciate your post - I "dug" my way into the instrument cluster and it was as you describe. BTW the quadrant that holds the indicator bulbs alternator and high beam has a third socket (in the middle - between the alt and the high beam - there was a globe in mine when I got the backing plate off) - any idea what it`s for?
Dug = remove glove box, to gain access to clock to allow it to be removed to allow radio plate to be deleted (after removing bottom cover plated under dash inc chrome slip) to allow access to heater controls to be removed to allow access to tach to remove it to allow access to centre instrument cluster ....whew. Friend of mine reckons it would be easier to remove the engine
So, all that to replace a 50 cent globe. Globe (for the alternator) replaced and tested and acts as it should, as do all the others. Reassemble cluster, reinstall and test again - alternator light still working, as is the high beam indicator BUT the instrument lights and the parking lights aren`t. Easy Peasy- must have blown a fuse - Nup, all of them are ok good so now I have to start back tracking to see what I have done GRRRRRR Any clairvoyants who could give me a clue would be welcome. At least I did`t get the whole dash back together before I tested.......
At least the path to the light didn`t include removing the blower (although not by much!)
