Author Topic: WTB: Seat Hinge Pivot Shoulder Bolt Hex Head  (Read 4253 times)
afeustel
  • USA, TX, Houston
« on: May 05, 2022, 02:44:31 »
Hello.
Does anyone have one of the seat pivot bolts that hold the top and bottom of the seat together and act as the pivot point?  It is number 25 in the attached Niemoller picture.  This bolt has a large shoulder and a hex drive on the head.
Thank for considering.
Drew
  • USA
Re: WTB: Seat Hinge Pivot Shoulder Bolt Hex Head
« Reply #1 on: May 10, 2022, 17:53:01 »
Believe I have one, but its not a hex drive head, but a large slotted end for a large screwdriver.
Think I have 25, 26, 12, 27, 13, 15 maybe 17.
Need to check my parts bin.
Can you wait till later this week?
Walter
  • USA
« Reply #2 on: May 12, 2022, 13:02:57 »
Still no reply from you, but here is a picture of the pieces I found.
If you are interested, send me a PM.
Walter
If anyone else needs these bits, send me a PM.
Would like to get $50.- for the set with USA shipping already included
Thanks.
« Last Edit: May 18, 2022, 15:40:09 by waltklatt »
afeustel
  • USA, TX, Houston
« Reply #3 on: May 22, 2022, 18:35:50 »
Hi Walter. Thanks for checking. I think that may actually be bolt 27, but I cannot tell for sure.
At the moment I have a friend cutting one on a lathe, using a close match from McMaster Carr that I ordered. Hopefully that will work as well.
Appreciate you digging those parts up. If the machined bolt doesnt do the trick, I may reach back out.
Regards and thanks again,
Drew
