Author Topic: need power steering pump tightening bolt  (Read 5142 times)
bcjm
« on: May 29, 2005, 22:45:25 »
I tried to replace my power steering pump blet today but I accidently borke the tightening bolt.  It is about 2"-3" long with a loop on one side and threaded on the other.  I did not see anyone sell them new.  If anyone has a used one I would like to buy it.
ChrisInNashville
  • USA, TN, Nashville
Re: need power steering pump tightening bolt
« Reply #1 on: May 30, 2005, 13:45:33 »
I bet your local hardware store will have one...unless it's been changed, mine is a standard wing nut.
‘69 280 SL
‘24 GLE450e
Tennessee, USA
« Reply #2 on: May 30, 2005, 14:13:37 »
I think Bob is referring to a somewhat more complicated bolt; I have a couple lying around but maybe finding one in the US will be cheaper on postage. Just let me know.
« Reply #3 on: May 31, 2005, 08:49:16 »
Try a Benz Dealer..
 part# 180 466 00 74
 It probably broke cuz there are 2 adjusting nuts locked together . You have to loosen one first in order to adjust the other ... if you do not , you will snap the bolt..
... or , go here
http://sls.sparebase.de/bin/dbframes.phtml?mid=IN02
 Go to English, then to power steering insert ..it is item #14..
"Bolt Clamp"
« Last Edit: May 31, 2005, 08:54:09 by A Dalton »
bcjm
« Reply #4 on: June 01, 2005, 07:15:14 »
That website looks great!!  A bit pricy after converting euro to dollar.
« Reply #5 on: June 01, 2005, 07:50:43 »
Easy to fab one by welding a washer on the end of a threaded rod..
Check with a Dealer , I think it is still available from Benz..
If not....
 Pay Cees the postage, shouldn't be more than a new one
bcjm
« Reply #6 on: June 18, 2005, 07:09:41 »
Does anyone have the part number for this bolt?  Local dealer ordered a wrong one.  Now they can't ever find the part number.
« Reply #7 on: June 18, 2005, 10:23:35 »
  I just re-checked my parts book and my earlier post part # should be correct...
aomastu
« Reply #8 on: January 21, 2007, 23:20:29 »
Recently bought a 280sl and decided to go after the power steering pump leak.  Several issues came up.  Sorry for the long post.  I got the car relatively inexpensively (<$20K) and think I have to rerepair some areas.  Please advise if possible.
I went under the car to check the pump, I found this bolt loose in the bracket below the pump.  It had a loop on one side and two bolts on the other.  It wasn't really attached in any useful way.  It stayed in place b/c the loop came out of the bottom of the pump bracket and the bolts went through a hole in its bottom side
Correct me if I am wrong -- Looking at the Haynes manual, it looks as though the loop is supposed to be attached to the pump.  After loosening the pump to bracket bolts, I am supposed to use this bolt to push the pump to loosen the belt?
Yipes! If this is supposed to loosen the belt, and it is gone, then do I use the same method of tightening the belt as I do with my American cars?  (tighten with bar and then tighten bolts).
Also, how many bolts hold the pump in place.  I count three.  Is this right?
I have some photos, but they are too big.  I'm going to buy some software tomorrow to resize them for posting.
Thanks for the fun.
'69 280sl
P.O. Box 150128
Austin, TX  78715
