Author Topic: Missing both data tags under bonnet  (Read 1405 times)
spence_pcs@hotmail.com
« on: May 18, 2022, 22:30:07 »
Hi, I recently bought a 1968 Rhd 230sl, it was a failed restoration about 10 years ago.
The problem I have is both data tags/plates have been lost when the engine bay and the rest of the body had a colour change. I have rubbed back the paint on the chassis number located on the inner wing and matches the V5. 2 questions. 1. How do I go about obtaining a data card with the full build specification? 2. Who can duplicate the 2 data tags/plates located within the engine bay, I believe one has pressed digits/numbers?
Thank you in advance for your help. Cheers Spence
Re: Missing both data tags under bonnet
« Reply #1 on: May 19, 2022, 03:58:41 »
Firstly, production of the 230sl ceased in January 1967 so not quite sure if you have the 250sl and wrong designation or the 230sl and wrong year..
You can get the data card from the MB Classic Center either Germany or in Irvine USA, but they will charge you $150USD for the privlage.
On the data plates there is a supplier that does them, a member here but don't know his name off the top of my head and maybe someone else can chime in here otherwise it will come up in our suppliers list.  https://www.sl113.org/wiki/Suppliers/Start
Another suggestion, join up  as a Full Member for $30 pa as this will then give you full access to the Technical Manual that will be vital to give you all the information you will need as a Pagoda owner and the ability to understand all the codes and information on each model of the Pagoda as well as a wealth of information to maintain your vehicle.
« Last Edit: May 19, 2022, 06:54:20 by Garry »
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
dirkbalter
  • USA, CA, Corona
« Reply #2 on: May 19, 2022, 04:42:22 »
For the tags go here:
http://www.pagode-markt.de/
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: May 19, 2022, 06:12:43 »
Spence, you’ll need the cash, plus provide them proof of ownership (v5 should do it) and (if you can) a pic of the vin number on the car (ie that you’re not trying to clone off the v5). They may still offer the data cards out of Germany but the US is the same but they’re really used to us lot!
The VIN should also be stamped on the right hand side front longitudinal frame in the engine bay. It’s under the large diameter duct pipe from the air filter
VIN 113 042 is 230, 113 043 is 250, 113 044 is 280
« Last Edit: May 19, 2022, 06:19:46 by JamesL »
