Author Topic: AC idler pulley retaining ring  (Read 2657 times)
Harry
  • USA, TN, Knoxville
« on: May 20, 2022, 00:29:00 »
When I removed the idler pulley to replace the bearing, the retaining ring bent and I need to replace it.  Does anyone know the right dimensions or clip to order?
Thanks as always!
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
dirkbalter
  • USA, CA, Corona
Re: AC idler pulley retaining ring
« Reply #1 on: May 20, 2022, 01:42:18 »
Unless someone knows the exact size, just measure the shaft OD. That’s the nominal retaining ring size you need.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Harry
« Reply #2 on: May 20, 2022, 12:47:12 »
Hi Dirk.  This retaining ring actually secures the bearing in the pulley, so it's an ID (versus OD) fitment.  I can measure the depth of the groove it fits in and the ID of the pulley to determine the actual ID size for the ring but I was hoping someone on the forum already had that information.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
