Author Topic: 1970 280SL cooling fan clutch  (Read 1835 times)
Jagoffizier
  • USA, VA, Stuart
« on: May 20, 2022, 19:57:15 »
The bearings on my original fan clutch are starting to go, so I plan to replace it soon. I would appreciate guidance on which aftermarket unit to install, as units no longer available from MB Classic.
Re: 1970 280SL cooling fan clutch
« Reply #1 on: May 21, 2022, 15:24:19 »
I just completed this job on my 250 SL. I did find the Behr clutch (OEM) and it was about $1000! I opted to continue looking. The folks around here were pretty well down on the URO unit. I found a Meyle from K&K out of Michigan and that is what I went with.
I did speak with my mechanic and he has been using Hudson.
Jagoffizier
  • USA, VA, Stuart
« Reply #2 on: May 23, 2022, 22:30:45 »
Thank you for your answer. I also want to avoid $1000, but don't want to be too cheap either.
WRe
« Reply #3 on: May 24, 2022, 04:50:02 »
here I can find cheap ones only: https://www.daparto.de/Kuehlerluefter-Kupplung/Mercedes-Benz-SL-Pagode-W113/3-9310a012-851. Maybe the Meyle would be fine.
...WRe
Jagoffizier
  • USA, VA, Stuart
« Reply #4 on: May 24, 2022, 13:50:46 »
Thank you for the reference.
Benz280
  • USA, NJ, Jersey City
« Reply #5 on: May 24, 2022, 14:08:33 »
Just replaced mine, given that I'm making every effort to retain OE on every part, was able to dig up a OEM MB part for $800.00
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Jagoffizier
  • USA, VA, Stuart
« Reply #6 on: May 25, 2022, 23:22:11 »
Thank you. I found a slightly used example and will have it installed next month!
