Author Topic: 280SL- M130 engine in late version  (Read 2055 times)
SEB
  • Germany, Berlin, Berlin
« on: May 21, 2022, 13:06:17 »
Hello evrybody!
I have a question, that I couldn't find an answer to both in Engelen's book and here on the forum.
From which 280SL chassis number the M130 engine was mounted in the late version?
Many thanks for help and greetings
Sebastian
1967 250 SL, 4 Speed, Euro spec, Tunis beige (462H),
Re: 280SL- M130 engine in late version
« Reply #1 on: May 21, 2022, 15:44:39 »
Seb - I don't understand the question.
"..M130 engine was mounted in the late version" Are you asking about a late version of the engine, a late version of the car?
I will check the M130 engine book, to see if it has any additional information and will amend this post if I find anything.
SEB
« Reply #2 on: May 21, 2022, 20:31:49 »
Hello Jonny,
we have to early version of the M130 engine and the late. My friend asked me from each 280SL car number was mounted the late version? I think the change was about 1970, but I could not find it in Engelen book.
Greetings
Sebastian
Sebastian
« Reply #3 on: May 21, 2022, 21:51:32 »
Change was in June/July of 1969. Slightly different for auto and standard trans cars probably due to what they had in stock on the line.
Kevkeller
  • USA, HI, Honolulu
« Reply #4 on: May 22, 2022, 05:34:08 »
What was the difference?
1970 280 SL
« Reply #5 on: May 22, 2022, 12:11:25 »
Round vs oval head combustion chamber.
MikeSimon
  • USA, OH, North Royalton
« Reply #6 on: May 22, 2022, 13:10:30 »
Frankly, I think there was also a change in the compression ratio, which was never made official or public. Many "late" heads do not show the compression ratio anymore, but some, for some markets do. The head on my car shows 9.0:1 instead of 9.3:1.
There was a "low compression" option, which my car does not have. It is a regular German spec car, built in late November 1970.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #7 on: May 22, 2022, 19:21:40 »
Different combustion chamber shape, longer head bolts, extra cooling passages in the block and head, different cam shaft and bearings, TTS and temp gauge probe moved to the back of the head. There were other smaller modifications made but those would be most of the more easily seen changes.
SEB
« Reply #8 on: May 23, 2022, 08:05:53 »
Gentlemen, thank you for all the comments, I finally found also the accurate information, so in the case of
M130.983-10-005301,
and in the case of
M130.983-12-008784
these were early versions. All numbers above were the late version.
Sebastian
MikeSimon
« Reply #9 on: May 23, 2022, 13:52:24 »
Buying a head gasket, or at least looking at the packages will shed light on this. They give the cut-off for the different designs of combustion chambers by VIN number
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
SEB
« Reply #10 on: May 23, 2022, 16:23:20 »
I agree, I found this information on the SLS website.
Sebastian
