Author Topic: ignition resistor & coil compatibilty ?  (Read 8127 times)
« on: May 21, 2003, 10:57:15 »
what kind of symptoms would a pagoda exhibit if its ignition coil & ballast resistor were incompatible?
« Last Edit: May 21, 2003, 14:27:23 by Douglas »
Re: ignition resistor & coil compatibilty ?
« Reply #1 on: May 22, 2003, 03:13:01 »
Douglas,
I ordered a replacement coil from my merc dealer to replace the standard black coil. Months later I realised from the labels that in fact it was a red coil. And the engine had been running fine with the 0.9 ohm ballast resistor.I have changed it now with a 1.8 ohm ballast.
My answer: If you didn't know the difference, you couldn't tell the difference.
'Kloines Scheisserle'
« Reply #2 on: May 22, 2003, 06:59:14 »
in terms of driveability, i think you're right. i suspect the difference would be premature wear on the plugs & points, but i was looking for confirmation.
« Last Edit: May 22, 2003, 07:00:14 by Douglas »
« Reply #3 on: May 22, 2003, 08:31:00 »
Douglas,
with a lower resistance ballast, I'd suspect maybe premature points wear, but also premature coil failure since it would be operating at higher voltage than it's designed for.
bayleif
« Reply #4 on: May 22, 2003, 15:46:06 »
Douglas,
In my case, the car would misfire on an irregular basis. It would cruise along fine for awhile, then miss for maybe 20 secs then run fine again. I don't know how long she had the wrong coil and ballast resistor she came to me that way. When I replaced the coil / resistor she ran much better. Then when I replaced the points, better again.
Chuck Bartlett
69 280SL
Chuck Bartlett
1969 Signal Red 4 Speed
