Author Topic: Emergency help for fuel? issue on trip today  (Read 2713 times)
H. Keith Henry
  • USA, VA, Yorktown, Va
« on: May 26, 2022, 14:06:40 »
I am on what is evolving into a shakedown cruise in my newly-purchased 1970 Pagoda. It performed well from SE Virginia to Iowa, but has developed a miss on the way back. A classic Mercedes mechanic in Des Moines thought it might be bad gas, but two tanks later the miss is still there. I am in Indianapolis today. Any advice for where to turn for help?
1970 280 SL, auto, US spec, 050 white with burgundy interior and soft top. Originally special order, white on white on white tex. Manufacturing date May 1970
2002 Mercedes C320 wagon
1989 Honda Civic wagon
1979 MG Midget, original owner
Re: Emergency help for fuel? issue on trip today
« Reply #1 on: May 26, 2022, 14:14:28 »
Join our Emergency Contact List (https://www.sl113.org/wiki/Main/EmergencyContactList) and download the list immediately afterwards...
H. Keith Henry
« Reply #2 on: May 26, 2022, 14:18:29 »
Thanks Peter. There are no club members on the list from Indiana.
« Reply #3 on: May 26, 2022, 15:02:45 »
Check the ignition points and the spark plugs. Sounds like the points may be closing.
H. Keith Henry
« Reply #4 on: May 26, 2022, 17:01:51 »
Thanks! What this trip is telling me is that I need to learn how to perform basic maintenance on the car.
« Last Edit: May 26, 2022, 19:25:32 by H. Keith Henry »
RAY
  • United Kingdom, England, Bromley
« Reply #5 on: May 26, 2022, 17:41:28 »
Check the plugs general condition, do you know if they are new, and the same with the points.
The plugs should be a light brown/grey in colour idealy but also not crusty, cacked up or oily. Yes check the gaps if you have some feeler gauges.
Could also be an HT lead that has suddenly 'broken down',  check to see if each plug is sparking.
What a pain after it was running so well.
« Reply #6 on: May 26, 2022, 17:42:11 »
As Ray types - for the plugs you are looking at color and condition (clean, dirty, white, oily) For a sign that something is different than the others.
There should be a spark plug wrench in the tool kit.
Be careful when screwing the plugs back into the head. The head is aluminum. Don't try to start them using the wrench. You should be able to use your fingertips to put the plugs in, they should screw in relatively easily, do not force them.
I tried the search function using "spark plug condition" (without the quote marks)
This was the second hit, but there were a number more.
https://www.sl113.org/forums/index.php?topic=34844.msg255102#msg255102
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #7 on: May 26, 2022, 17:56:13 »
There is Indianapolis 500 section of the Mercedes Benz Club of America.  Roger Brummett is listed as the contact there.  317-721-2784  roger@metroevelvator.com
« Reply #8 on: May 26, 2022, 17:59:40 »
Just because people have not joined the list doesn't mean they won't offer some kind of assistance. Many people just don't bother to react to emails, requests, etc.
We have nine members in Indiana. Five are full members, four are associate. One of the full members, Wen Gagne, is in Indianapolis. Look him up on our member list and try to reach out, maybe he has a local mechanic who can help.
Also, check here: https://www.benzshops.com/near/indianapolis-in
Kevkeller
  • USA, HI, Honolulu
« Reply #9 on: May 26, 2022, 18:24:40 »
Try pulling off one spark plug wire off at a time and see if the missing is confined to one cylinder only. If it is maybe it’s not the points.
1970 280 SL
« Reply #10 on: May 26, 2022, 18:34:44 »
It's in general a good idea to learn some basic diagnostics and mechanical work on these, or any for that matter, cars.
Another advice I would offer, too late in your specific case, is to avoid shakedown cruises that take you far from home. Me, I take new-to-me-cars that are old and/or suspicious in terms of reliability around the block first a couple times (so I can walk home if necessary. I have had to on occasion), then if that goes well in wider circles but still within a mile or two, and gradually increase the risk.
Neither of these things can guarantee you won't get stranded someplace, but they help to reduce that risk. Now, but only after quite a few years of shade-tree experience, I can say that it's been more than 10 years since I've had to have any car serviced or repaired by a professional garage.
H. Keith Henry
« Reply #11 on: May 26, 2022, 19:35:05 »
Thanks all. I will try contacting local club members. I should have said, in the first place, that the plugs and one plug wire, were replaced only last week after I first experienced the car "missing." The DSM-area mechanic tentatively concluded that it was a case of bad gas, but after two more tanks the symptom persists. Quite possibly sludge in the tank and/or fuel filter which will probably need to wait till I get home, assuming I get home without a problem.
« Reply #12 on: May 26, 2022, 20:04:57 »
If your coming through Columbus Ohio on I-70, you'll pass close to Blacklick, Ohio  and I probably can take a look at it for you.
« Last Edit: May 26, 2022, 20:40:11 by ja17 »
H. Keith Henry
« Reply #13 on: May 26, 2022, 20:25:20 »
Thanks Joe. An offer I can't refuse. I will alter my route to go through Columbus/Blacklick. My present plan, assuming the car is running well enough to resume the trip, is to leave Indy early on Monday, the 30th, which is Memorial Day. If that is not convenient, I can leave a day or two earlier.
« Reply #14 on: May 26, 2022, 21:03:15 »
Call me 614 312 2865
ChrisInNashville
  • USA, TN, Nashville
« Reply #15 on: June 03, 2022, 00:39:48 »
I’m sorry I’m just seeing this. If you can get 45 miles south to Bloomington, Jorn Kallum.  Quality Import Service.
‘69 280 SL
‘24 GLE450e
Tennessee, USA
« Reply #16 on: June 03, 2022, 15:42:49 »
I do a 555 until I'm satisfied that everything is working. 5 miles, 50 miles, and then 500 miles on fresh rebuilds. 5 mile trips can be several times until I have all of the tuning done.
The object here is to simulate all driving conditions. Short trips, cold starts, hot starts, longer one hour trips, high speed interstate driving, around town, stop and go driving, night time driving, and if I can, driving in the rain at night. If I can't find any problems during all of that driving, I call it ready to go.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #17 on: June 04, 2022, 14:18:46 »
Keith, I know you are worried, it is the person you are. Also a miss in the engine is 99% plug miss. What ever you do, please take to Joe. He is the man. Remember I told you when I visited you when you received your SL that he was the authority. He will have your car running as smooth as ever. Have a safe trip and let me know when you get back, we’ll do lunch.
Robert Hyatt
Williamsburg, VA.
dpreston Virginia
  • USA, VA, Salem
« Reply #18 on: June 04, 2022, 17:25:46 »
As a general rule carry an extra set of plugs maybe two. All my misses have been due to fouled plugs, most likely for me too much idling when starting up. Start the car and go don't let it sit and warm up.
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
H. Keith Henry
Re: Emergency help for fuel? issue on trip today - update
« Reply #19 on: July 02, 2022, 16:33:34 »
Thanks again, everyone. I meant to provide an update before now. I had a highly successful trouble-shooting session with Joe Alexander, Saturday morning, May 28. Joe quickly diagnosed my remaining miss as burned points and, of course, he had them in stock! After that, and other fine-tuning at Joe's, the car ran exceedingly well all the way from Joe's garage in Columbus to my home in SE Virginia late that same evening. I had a smile on my face the whole way!
