Please check out joining the
Emergency Contact List
for help during your travels!
Rear driver side brake hard line
Topic: Rear driver side brake hard line (Read 1659 times)
Chris Long
Associate Member
Senior
USA, NJ, Morristown
June 06, 2022, 16:24:00 »
Does anyone have a picture of the routing? I just had new lines installed and they appear to be routed across the top of the axle under the bump stop which seems incorrect.
Thank you
1970 280sl 4-Speed Horizon Blue
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Re: Rear driver side brake hard line
June 06, 2022, 17:33:48 »
It should be towards the rear at about the 3 o'clock position.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #2 on:
June 06, 2022, 17:37:24 »
Agreed. The bump stop needs to clear the brake line.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Chris Long
Associate Member
Senior
USA, NJ, Morristown
Reply #3 on:
June 06, 2022, 20:45:38 »
Thanks - Anyone have a picture; Wonder if they mounted the L & R split wrong which has thrown everything off
badali
Full Member
Platinum
USA, Pa, Butler
1966 230SL
Reply #4 on:
June 06, 2022, 21:05:23 »
Here is mine.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
Chris Long
Associate Member
Senior
USA, NJ, Morristown
Reply #5 on:
June 07, 2022, 11:47:30 »
Thank you very much.
