Author Topic: Fan Clutch  (Read 1695 times)
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Fan Clutch
« on: June 08, 2022, 17:28:27 »
My wife and I were cruising last Saturday afternoon. We took a spin through our downtown area looking for a place for lunch. For the first time in the 11 years, my Pagoda over heated. Didn't want to risk any damage so I had the car towed to the dealer I use. They diagnosed the problem as a bad fan clutch. They quoted me a total of $3800 for the repair including labor. They've usually been fair because they view my car as a rolling advertisement...but, that seemed high.
I would appreciate any perspectives from this group.
« Last Edit: June 08, 2022, 17:41:21 by 71Beige280SL »
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
Re: Fan Clutch
« Reply #1 on: June 08, 2022, 17:59:39 »
That's insanely high, if it's just to replace the fan clutch?
There was another thread here recently about good quality and original fan clutches - as often, the good quality non-OEM are a fraction of the one MB sells but should be fine. I think under $100? Then figure maybe an hour max to put it in? Maybe they did not provide you all the information about what they think needs doing. Has to be something like that, or a mix-up with someone else's car.
Re: Fan Clutch
« Reply #2 on: June 08, 2022, 18:05:33 »
I just replaced mine, and went with a Mehle unit at a tick over $250. The Behr clutch was about $1000!! There are much cheaper URO units at under $100, but I would be skeptical of those. Another decent brand is Hudson.
I replaced it myself, but my car does not have a shroud around the radiator, and that would complicate things. I also did not need to take off the hood (or drop the radiator out the bottom).
It is a bit of a squeeze to get the fan in and out, especially if you have the spacer on the front of the water pump puller. Patience won out
I also put thin cardboard between the fan and the radiator to protect the radiator.
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Fan Clutch
« Reply #3 on: June 08, 2022, 19:20:07 »
Thanks Johnny B and Cees. I looked into the costs further. Both the thermostat and fan clutch need to be replaced. Total parts cost is $1019. The thermostat is a Mercedes part but the fan clutch is aftermarket from a company called Adsit (www.adsitco.com) out of Eaton, Indiana. The rest was an estimate of labor. I'll be looking into it further.
Re: Fan Clutch
« Reply #4 on: June 08, 2022, 20:08:22 »
I will go back to Cees's comments, that is crazy expensive. A thermostat is in the $50 range, and the clutch from Mehle is $250. I would definitely double check the brand on the Adsit fan clutch.
I bought the fan clutch from KK Mfg out of Michigan.
Kevkeller
  • USA, HI, Honolulu
Re: Fan Clutch
« Reply #5 on: June 08, 2022, 20:45:55 »
I think they’re taking advantage of you also. Parts made in India don’t cost that much either.
1970 280 SL
Re: Fan Clutch
« Reply #6 on: June 08, 2022, 22:37:02 »
Adsitco fan clutch as per their website for a 280 SL costs $110.
WRe
Re: Fan Clutch
« Reply #7 on: June 09, 2022, 05:22:53 »
here you can check prices for fan clutches (in Germany): https://www.daparto.de/Kuehlerluefter-Kupplung/Mercedes-Benz-SL-Pagode-W113/3-9310a012-851. I would take a Meyle.
...WRe
mauro12
  • Italy, Sicily, Messina
Re: Fan Clutch
« Reply #8 on: November 05, 2024, 18:23:41 »
Hi guys , I want to replace my fan clutch but I’m reading some different opinions about Oem and aftermarket . Spending 1000€ for genuine Mercedes is too much , also I’ve checked that right now is nla .
Any negative issues with meyle or febi ?
Some people say that those engage too early and causing a power loss in the car . What is your opinion on that ? What should I buy ? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
