Author Topic: Correct Setup for M130 Short Pump Fuel Lines?  (Read 1407 times)
travisdutton
  • South Africa, KwaZulu-Natal, Pietermaritzburg
« on: June 09, 2022, 19:37:10 »
Hi all,
I recently got my car back from a somewhat sketchy mechanic who tried to rebuild my short pump. The fuel pump has been restored and I am looking to fit it back in myself. It is a Bosch short pump with the part number 0 442 201 007.
One thing I have questions about is the return line from the injector pump. I have read that there must be a T join with one line going back to the tank and the other to the fuel pump? Or can I run the return straight back to the tank?
If there is no T, do I need a bleed screw for the pump, maybe run a line from that port somewhere?
Thanks very much
TJMart
  • USA, NC, Matthews
Re: Correct Setup for M130 Short Pump Fuel Lines?
« Reply #1 on: June 10, 2022, 14:35:50 »
There should be a "T" that splits the return line to the fuel pump and the tank. See this link  https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/47-fuel-tank  #141
Tony
1970 280SL, 4 Speed
