Author Topic: Drive shaft bolts  (Read 1514 times)
mikeswplt
  • USA, TX, Lago Vista
Drive shaft bolts
« on: June 10, 2022, 13:42:24 »
Would appreciate any info on the bolts used to attach the drive shaft to the flange on the
rear end. I’ve been unable to locate the 4 bolts/nuts/washers that were removed when the 250SL I’m restoring was dismantled. The parts diagram doesn’t display them or reference any part number. A photo I saw online showed what looked like a nut retainer
as part of the connection.
‘68 250SL    under restoration
‘11 RR Sport
‘22 Silverado 2500HD
‘95 F355 GTB
mikeswplt
Re: Drive shaft bolts
« Reply #1 on: June 10, 2022, 16:15:28 »
Talked to MB classic and bolts are listed as cheese head screw NLA. Nut retainer is lock plate, no washers required. Need to source a used set of bolts or find a suitable substitute.
‘11 RR Sport
‘95 F355 GTB
dirkbalter
  • USA, CA, Corona
« Reply #2 on: June 10, 2022, 17:06:57 »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: June 11, 2022, 03:39:17 »
I have plenty of good used bolts. They were used many of the common sedans of the era.
mikeswplt
« Reply #4 on: June 12, 2022, 21:43:42 »
Thanks for the offer Joe. I was able to get the bolts I needed off a 220S parts car at a local independent MB repair shop.
‘11 RR Sport
‘95 F355 GTB
