In my continued search to identify a cold start idle issue, new WRD thermostat replaced.
Starts are very low RPM, stalling occasionally. Burps, spits a bit until warm.
Once warm idles around 1000, reducing idle with air screw affects initial cold start and won't idle unless accelerator is maintained.
I'm thinking , initial start up should be around 1200 RPM then drop to around 850 once warm .
