Author Topic: 1983 MB 280 SL - 107  (Read 7369 times)
zak
  • USA, NJ, Bernardsville
« on: June 29, 2022, 21:16:19 »
The trouble lights came on the other day for the battery and alternation. So I assume the original alternator is shot. For years at low idle and headlights on the battery trouble light would glow.
For those of you who have 107s, is there any reason to upsize the alternator to handle the electric loads ?
I have had this tank for 10 years and it never let me down. so I want to do the right thing.
thanks,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
ejboyd5
  • Southold, NY
Re: 1983 MB 280 SL - 107
« Reply #1 on: June 29, 2022, 22:04:52 »
Don't complicate your life.  If you haven't added any consumers, don't plan on adding any, and everything has been working well to date, stick with what you have. BTW, you are only assuming that the alternator is "shot."  Have it examined by a reputable repair shop before committing any big $$$; it may be a simple fix is all that's necessary.
franjo_66
  • Australia, NSW, Point Piper
« Reply #2 on: July 01, 2022, 01:36:12 »
Zak it could be something as simple as your belt requiring tightening, or you may need a new alternator. But get someone to check it out. the 107s are an easy car to diagnose for the basics
Good luck!
Franjo
1965 230SL Black/Auto/RHD
2005 Porsche Cayenne Turbo
1983 BMW 735i
1986 560 SEC
1991 500SL
1982 Holden Statesman DeVille
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: July 01, 2022, 11:53:45 »
I don't know, but does the "alternator" in the 107 have brushes?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
zak
« Reply #4 on: July 01, 2022, 15:27:53 »
I drove it to the shop this morning. Belt is tight with no squeal.
Red battery trouble light has remained on.
I will know the problem soon.
I don't know about brushes, Make S.
thanks,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
zak
« Reply #5 on: July 05, 2022, 20:46:37 »
I got a new Bosch 70 amp alternator installed on Friday and with it the car runs better than ever.
In hind sight,  the original alternator light always glowed red at low idle in gear. The electric windows also caused the red light to go on when I closed the windows and if I closed both windows at the same time the idle would slow a bit and the engine changed sound, like it was straining a bit.
Now it seems that the car runs crisper and responds a bit more quickly... and the windows go up more quickly.
All is well now.
thanks,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
