Author Topic: Trace replacement engine to specific original car?  (Read 2077 times)
H. Keith Henry
  • USA, VA, Yorktown, Va
« on: July 03, 2022, 14:46:53 »
I've done just enough research on my new-to-me 280 SL to know that I should be happy to have a replacement engine that runs well and not worry that it is not original to the car. So, I'm fine with that. But, out of curiosity, I have the opposite of the usual engine-chassis question: Is there a way to take my engine serial number and match it to a VIN number to determine exactly which car it came from?
1970 280 SL, auto, US spec, 050 white with burgundy interior and soft top. Originally special order, white on white on white tex. Manufacturing date May 1970
2002 Mercedes C320 wagon
1989 Honda Civic wagon
1979 MG Midget, original owner
roymil
Re: Trace replacement engine to specific original car?
« Reply #1 on: July 04, 2022, 02:35:17 »
This is an excellent question I'd also be curious about.  The main reason to know is so that you can correctly source spare engine parts with some confidence.   Not all parts are easy to figure out.   I *think* I currently have a factory rebuilt engine from a 280SE, installed sometime in the early 90's,  but I'm not completely sure which type of oil pan, pump, and pickup are correct for this specific block.  I shared part numbers with a well known parts supplier and they didn't think my oil pump was from an SL or an SE.  It works fine but I'm stumped.
Reverse lookup of the engine serial number would be a great help.
Mark Miller
1968 280SL
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: July 04, 2022, 12:48:25 »
You can not. While it is possible to narrow down the car model - M130-980, -920,-983 etc, and the manual or AT transmission application using the engine serial number and with that the approximate build date, assigning an engine to a specific car is next to impossible.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
H. Keith Henry
« Reply #3 on: July 04, 2022, 14:43:50 »
How does one use the engine serial number to "narrow down the car model?"
dirkbalter
  • USA, CA, Corona
« Reply #4 on: July 04, 2022, 16:01:38 »
Take a look here.
https://www.sl113.org/wiki/DataCard/EngineNumber
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
H. Keith Henry
« Reply #5 on: July 04, 2022, 17:28:37 »
Got it. Thanks. A well-done explanation.
Berggreen
  • Denmark, Zealand, Gentofte
« Reply #6 on: July 14, 2022, 15:45:09 »
.....agree, but not complete. In fact the M130.981 engine is missing in the list. This engine has identical specs to the M130.983 (280SL), and was used in the w109 300 SEL 2.8L model. This engine was attractive as a replacement for the M130.983, due to the identical specs. I have one in my 280SL from 1970. :)
Cheers,
Christian
02/1971 MB 280SL (aut.) - olive green 291H
11/1970 MB 280SL (man.) - silver 180G
12/1977 MB 350SE (aut.) - deep green 825H
03/1969 Volvo 1800S (man.) - dark green 94
Desertpagoda
  • USA, AZ, Tucson
« Reply #7 on: July 29, 2022, 00:40:09 »
me too, i bought a t-boned sedan with this engine and rebuilt it for my sl, the cam was always noisey though and i finally changed it for a less rampy cam and truthfully didnt notice any loss
kb
