with our official
Pagoda SL Group logo
from our official partner.
Front suspension spring spacer
Topic: Front suspension spring spacer (Read 1470 times)
afibbe
Full Member
Senior
USA, OH, Cincinnati
513-374-5600
July 11, 2022, 01:09:26 »
I am in the process of reassembling my ‘66 front suspension. When I took it apart, there was a 1/4” plate that someone had fabricated and installed between the chase with the bolts and the springs. The BBB does not show this spacer. Any thoughts on why someone would have installed the spacer? Do you think there is any reason to reinstall the spacer?
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: Front suspension spring spacer
July 11, 2022, 01:39:36 »
No spacer afaik. Make sure you have the correct rubber insert. Your car should have the bigger bar and also the bigger diameter rubber.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #2 on:
July 11, 2022, 01:53:28 »
On second thought, I remember a TV show, Phantom Works, where the guy "restored" a 230sl and ended up spacing the sway bar in order to clear the AC unit. Probably not your issue but may sure you clear everything when or if you remove the spacer.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
afibbe
Full Member
Senior
USA, OH, Cincinnati
513-374-5600
Reply #3 on:
July 11, 2022, 09:56:39 »
My car had air conditioning at some point in its life. When I got the car the compressor was still attached to the engine. I plan to add the plates to my box of stuff to be repurposed. Thanks for your help.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
