Author Topic: subframe mounts  (Read 1882 times)
Davek1
  • United Kingdom, England, Wells
subframe mounts
« on: July 21, 2022, 17:24:49 »
Hi all, I wonder if someone could advise me. I am looking to replace my subframe mounts as mine are shot. MB are asking around £650 for the kit where as after market ones are around £200. Is the much difference in them and who makes the MB mounts as there must be a massive mark up on them. Are the MB ones just far superior to after market ones. Thanks
Kevkeller
  • USA, HI, Honolulu
Re: subframe mounts
« Reply #1 on: July 22, 2022, 03:15:38 »
I think there’s a lot of previous discussions on the topic and which brands might be better.
1970 280 SL
Re: subframe mounts
« Reply #2 on: July 22, 2022, 03:22:42 »
The biggest expense in the kit is the metal parts which are normally not needed.
lagolag
  • Sweden, Västra Götaland, Askim
Re: subframe mounts
« Reply #3 on: July 22, 2022, 10:37:51 »
I did mine a couple weeks ago at the same time I did the engine mounts and did the rear axle centermount the week before, all aftermarkets parts, now it feels much better and as I only drive part of the year I think the aftermarket parts will do the job as good as the OE for me.
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
Davek1
Re: subframe mounts
« Reply #4 on: July 22, 2022, 16:59:01 »
I was thinking of just buying the mounts as I can reuse all the other bits, if I was to go down the after market route which ones should I go for as the all look identical and which ones to avoid
dirkbalter
  • USA, CA, Corona
Re: subframe mounts
« Reply #5 on: July 23, 2022, 02:47:33 »
You can buy the aftermarket ones for a 108 for example. about $100. (Febi / Bilstein)
Also:
https://www.sl113.org/forums/index.php?topic=14056.0
« Last Edit: July 23, 2022, 03:03:45 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Desertpagoda
  • USA, AZ, Tucson
Re: subframe mounts
« Reply #6 on: July 29, 2022, 00:34:10 »
lemforder is where the party is
kb
Davek1
Re: subframe mounts
« Reply #7 on: August 07, 2022, 21:07:06 »
Have chosen to give the aftermarket ones a go. Saving of around £350 against the MB 108 kit. Would be nice to know who makes the MB ones though
