Author Topic: Transmission wire grommet  (Read 1311 times)
edwardburak@erols.com
  • USA, VA, Marshall
« on: July 25, 2022, 12:28:00 »
1969 280sl USA Version Automatic
Hello, I am looking for the grommet pictured.
It carries wires from the footwell into the side of the transmission for the terminal block.
thanks
Re: Transmission wire grommet
« Reply #1 on: July 25, 2022, 15:34:55 »
Is this the bad boy?
https://www.authenticclassics.com/DUAL-HOLE-GROMMET-FOR-WIRING-HARNESS-p/auth-004526.htm
Go to authenticclssics.com, then select 113 car - then just type "grommet" (without the quotes) in the search field. It yielded 2 pages of items, easy to scan through. The one above looked like the one you circled - but hard to tell.
You can also check the usual suspects
kkmfg
Buds Benz
Millers
Good luck
  • USA, VA, Marshall
« Reply #2 on: July 25, 2022, 16:40:56 »
Thank you, that might be the correct one
