Please check out joining the
Emergency Contact List
for help during your travels!
General Discussion
Adjusting Trunk Lid
Topic: Adjusting Trunk Lid (Read 3772 times)
knirk
Adjusting Trunk Lid
June 04, 2005, 08:13:19 »
My trunk lid is not coming down enough so it is not flush with the fenders. I figured that this could be adjusted either on the lower or upper lock unit. The upper lock can be adjusted forward/aft, sideways and down by placing shims underneath, but not upwards. The lower lock cannot be moved at all. Anybody ever done this :?:
Download Attachment:
45.35 KB
72.28 KB
49.22 KB
Per G. Birkeland
69 280 sl aut 834
Norway
terry shores
Re: Adjusting Trunk Lid
June 04, 2005, 22:32:49 »
I had the same problem, there are rubber stops on each outer edge of the trunk lid. I raised one by adding a rubber washer and it made my gap perfectly even!! Maybe both of yours need to be taken down a little
knirk
Reply #2 on:
June 05, 2005, 07:44:38 »
No rubber stops on mine. The only thing that determines how low the lid can go is the lock.
Per G. Birkeland
69 280 sl aut 834
Norway
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Reply #3 on:
June 05, 2005, 08:19:22 »
I've got rubber stops on the rear lip of my trunk lid. I don't know if they're adjustable. They spin, but don't seem to go in/out.
1966 230SL, Euro, Auto, Leather, both tops
Reply #4 on:
June 05, 2005, 08:49:24 »
There should be a fairly large round rubber bumper on the left and right sides of the lid. They pop into the holes you'll see there.
General Discussion
Adjusting Trunk Lid
