Author Topic: Under wing/fender closure panel fixings  (Read 2832 times)
gordon
  • United Kingdom, England, Burntwood
« on: July 28, 2022, 12:58:42 »
Hi, can you please advise me as to the type /size of fixings used to fix the closure panels in place under the front wings/fenders adjacent to the toe boards.  Are self tapping screws used into a plastic inserts? The holes in the new panels are quite large presumably for adjustment purposes so i guess washers are needed. Thanks
Leester
  • USA, VA, Lorton
Re: Under wing/fender closure panel fixings
« Reply #1 on: July 29, 2022, 19:16:32 »
Hello Gordon, if you are speaking of the splash shields (see photo) I am ordering M6.3 X 20 hex head self tapping screws plus washers. Six each side. Hopefully you can find them more locally. In the US I order from Bel-Metric in Mass. If you were speaking of a different panel please ignore.  Lee
Lee Backus
1963 220SE Cabriolet
gordon
« Reply #2 on: July 30, 2022, 19:50:43 »
Thanks Lee, I got some today with flanged heads, (10 mm spanner fits)
« Reply #3 on: August 04, 2022, 02:18:37 »
Original heads.  For what it's worth the Mercedes current part is totally wrong and shockingly expensive.  I have a whole bag of them as they were special order and I refused to use them.
« Last Edit: August 04, 2022, 16:45:55 by Shvegel »
Delvis
  • Canada, British Columbia, Delta
« Reply #4 on: August 08, 2022, 07:05:53 »
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
Leester
  • USA, VA, Lorton
« Reply #5 on: August 08, 2022, 13:39:32 »
They look correct but $6 each.
Lee Backus
« Reply #6 on: August 10, 2022, 00:58:06 »
Belmetric.  Pennies each. Not sure of size if anyone can fill that in?  The official term is a Loose Washer Tapping Screw if that gets anyone closer outside the US.
https://belmetric.com/screws/loose-washer-tapping/
« Last Edit: August 10, 2022, 13:11:38 by Shvegel »
Delvis
« Reply #7 on: August 11, 2022, 07:38:42 »
hello,
I've measured the collar washer at 17mm,  total screw length of 18mm, indented hexagon head is 8mm socket size.
great find Shvegel (belmetric)
regards,
Dev
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
Delvis
« Reply #8 on: August 11, 2022, 16:58:56 »
additional info. the measurement from below the hex head/washer is 13mm
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
« Reply #9 on: August 11, 2022, 18:53:15 »
Probably a 15 mm length as it is measure from below the head of the screw to the tip.  If someone can measure diameter and compare it to the first page after the index here?  Pretty sure it is a 5.5mm but not 100 percent.
Delvis
« Reply #10 on: August 11, 2022, 19:11:36 »
here you go.
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
« Reply #11 on: August 12, 2022, 22:48:58 »
looks like 5.5mm X 18 with an 18mm washer.  Screw diameter is measured off the widest part of the threads (Major diameter).
18 long,18 flange, Yellow zinc
https://belmetric.com/m5-5-loose-washer-tapping-steel-zinc-plated/?
« Last Edit: August 17, 2022, 12:42:18 by Shvegel »
Delvis
« Reply #12 on: August 14, 2022, 00:24:15 »
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
