Author Topic: Question from ROOKIE????  (Read 4144 times)
terry shores
« on: June 04, 2005, 13:35:39 »
I have a red pagoda.  Behind the grill on the drivers side next to the radiator and in front of the battery is a piece of sheet metal about 9 inches wide.  Looking through the grill from the front of the car, I can see that this sheet metal has been painted red!!  DID IT COME FROM THE FACTORY LIKE THAT OR IS IT SUPPOSED TO BE BLACK SO THAT IT IS UNNOTICED??????  DO I NEED TO PAINT IT BLACK?????
THANKS,
TERRY
Re: Question from ROOKIE????
« Reply #1 on: June 04, 2005, 15:54:21 »
It should be painted black (flat or satin, like the radiator or inside the trunk - not too shiny!).
Kenneth Gear
  • USA, VA, Fairfax Station
« Reply #2 on: June 04, 2005, 16:31:09 »
http://www.motoringinvestments.com/RestoLog3.htm
Here's a link from a recently completely restoration which shows the black paint on the sheet metal at the battery which was brushed on at the factory.
Ken G
1971 280 SL
Silver/red
Ken G
1971 280 SL Silver/red
terry shores
« Reply #3 on: June 04, 2005, 20:06:25 »
Ok!! I spent the last hour painting that piece black.  Turned out nice!! THANKS ALOT TO BOTH OF YOU WHO RESPONDED!! I had seen a couple of restorations where that piece was painted the same color as the car, so I just wasn't positive!!!
« Reply #4 on: June 05, 2005, 08:11:41 »
Terry,
That's a common mistake.  Other common paint mistakes:
- Engine bay (under hood, inner fenders, etc.).  Engine bay should be body color except the part you found and the curved plate behind the big air filter housing.  Many times the whole think is painted black.
- Trunk lid.  The inside of the trunk lid and the inside of the trunk is painted the dark satin grey (almost black).  The inside of the soft top lid is also this color.
- Rocker panels are typically dark grey/black.
Anyone else care to add more common painting errors to watch for?
« Reply #5 on: June 05, 2005, 17:26:15 »
Oh why not! Usually, the inside of the wheel wells are painted body color, though there have been some exceptions noted.
« Reply #6 on: June 05, 2005, 18:34:03 »
I'll add a couple that I think I'm right about. While the underside of the hood (bonnet) is body color, the hood rod & spring that spans it is not. Some kind of metal covering. Same goes for the hood latch on the firewall and the door check cams. Not body color. I'd show pictures but mine ARE painted ala a low-end paint job!
« Reply #7 on: June 05, 2005, 18:55:08 »
Terry,
Go to the site Ken Gear mentioned earlier and study the restoration log. You'll see exactly what details to look for and to emulate. The site is:
http://www.motoringinvestments.com/RestoLog.htm
Brian did an excellent job of hunting down a very original CA car and restoring it for a client who frequents this message board.
