Author Topic: Forgotten where they go!  (Read 2624 times)
Minerva
  • Ireland, Connaught, Manorhamilton
« on: July 31, 2022, 10:52:52 »
Small bit of help needed, I've a couple of bits that I cant just place where they go, took loads of pictures, but just cant place these bits.
From a 280sl RHD.
One is a light weight bracket, bolted one end and the other side looks like a hole for a grommet.
Other is a heavy gauge bracket.
And lastly is a buffer, it was in the bag with the fuel tank mounting nuts and washers, but just not sure where it goes.
Thanks in advance for the help!
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Re: Forgotten where they go!
« Reply #1 on: July 31, 2022, 13:05:42 »
try.
1. should be from the engine compartment.
2. stop for the seats
3. could be a holder of the fuel tank.
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #2 on: July 31, 2022, 14:03:52 »
Replaced my gas tank recently, so I'm familiar with #3. It holds the corner of the gas tank near the fuel pump.
Lori
1968 280SL (US)
« Reply #3 on: July 31, 2022, 15:21:50 »
The middle picture looks like the piece that fits in front of the driver's seat for the fire extinguisher.  I may be wrong on what the clip is for, but that is where it is placed. Kind of hard to tell from the photo, but the brighter red is the front of the seat, to the left is one of the seat tracks, below the piece you can see the edge of the floor mat.
Picture attached.
« Last Edit: July 31, 2022, 22:31:33 by Jonny B »
Minerva
« Reply #4 on: July 31, 2022, 21:32:41 »
Great stuff thanks, we've got 2 out of 3, would never of found the seat one!
Thanks Folks
« Reply #5 on: August 01, 2022, 00:09:40 »
Just a thought:  RHD cars may have longer lengths of something that is a shorter length on a LHD car.  #1 looks like the kind of support bracket that would have a rubber grommet in the larger hole through which a brake line, vacuum or screen washer hose, some wiring, or perhaps a temp gauge capillary tube might pass.
Ben Roberts
  • Australia, South Australia, Adelaide
« Reply #6 on: August 01, 2022, 00:57:39 »
I could stand to be corrected but I used the first bracket to route the RH horn wire. Happy to be shown a better use for it!
Ben, Adelaide. Australia
1969 280SL, RHD, 906G, 904G
Minerva
« Reply #7 on: August 02, 2022, 16:27:30 »
Thanks Mike and Ben,
you could be right, the horn area is about the only are I didn't photograph when i was taking it apart, its definite that a grommet is one end the the other is bolted.
Thanks again.
Keith
Duncan200
  • Just started my Restoration
« Reply #8 on: August 24, 2022, 12:35:48 »
Ben is correct about the bracket, it mounts on the bolt the right horn is fitted with, but it holds the alternator and starter motor feed wires from the main loom down the right chassis rail.
Doug
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Harry
  • USA, TN, Knoxville
« Reply #9 on: September 17, 2022, 11:20:18 »
Alternate idea for first photo.  Looks like the bracket that mounts onto the top right brake booster stud and supports the oil pressure capillary tube.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
JohnnyC
  • USA, CA, Escondido, CA
« Reply #10 on: September 18, 2022, 00:37:17 »
Here's a picture of the gas tank holder.
Cheers,
JohnnyC
John
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
Harry
« Reply #11 on: September 18, 2022, 14:13:22 »
Checked the holder for the oil pressure capillary line, and the bracket in your first photo is not it after all.  Sorry.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
