Author Topic: Power adaptor options when lighter socket fit is an issue?  (Read 2491 times)
H. Keith Henry
  • USA, VA, Yorktown, Va
On my first cross country trip with my 280 SL, I discovered that my iPhone charging cable does not fit snugly enough into the car's lighter plug socket to make a good connection. That created problems at several points on the trip after the iPhone battery died a few hours into the driving day.
I am advised by a Mercedes mechanic that trying to adjust the socket is a tricky and inadvisable approach. He recommends installing a socket -- perhaps a USB socket anchored in the center tray -- as a more desirable solution.
Questions: Do you agree and, if so, what is the most desirable upgrade -- a USB socket or something even newer?
1970 280 SL, auto, US spec, 050 white with burgundy interior and soft top. Originally special order, white on white on white tex. Manufacturing date May 1970
2002 Mercedes C320 wagon
1989 Honda Civic wagon
1979 MG Midget, original owner
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
Re: Power adaptor options when lighter socket fit is an issue?
« Reply #1 on: August 03, 2022, 16:22:37 »
I had my Original Becker radio innards updated with new solid-state electronics and their USB option. I attached an extension cable to their USB cable and ran it under the carpet and into the center console right at the front, where I connect it to my iPhone.
http://garytayman.com/stereo.htm
RB
ejboyd5
  • Southold, NY
« Reply #2 on: August 03, 2022, 17:10:29 »
Put some electrical tape on the charger's plug opposite the spring to thicken the plug's diameter and you'll be good to go.
H. Keith Henry
« Reply #3 on: August 03, 2022, 17:12:17 »
Thank you! I have since seen the Dec 2020-2022 thread on the same topic that I did not see after my first search on the site. But I still welcome additional thoughts on the topic.
