Author Topic: Oil changes are easy!  (Read 6724 times)
« on: August 05, 2022, 17:50:57 »
…it’s removing the oil filter that’s always messy!
Kevkeller
  • USA, HI, Honolulu
Re: Oil changes are easy!
« Reply #1 on: August 05, 2022, 19:43:16 »
Nice grass.
1970 280 SL
« Reply #2 on: August 05, 2022, 22:46:44 »
Michael,
You need a hoist, even if it is just the X lift type………….
« Reply #3 on: August 06, 2022, 16:08:39 »
« Reply #4 on: August 06, 2022, 16:12:25 »
I'd love a lift of any kind. Would make many things easier. However the oil change mess is purely because of the location of the oil filter canister, AND the fact that it is horizontal. Even after letting everything drain there is no way not to spill a little oil from the canister/filter assembly once you get it off. Oh, yes, I've tried to stuff some rags in there, and caught some of it but sometimes they just get in the way. Not all the stains on those pieces of cardboard are from THIS oil change. Some are the various leaks from sitting, or working on bicycles or any number of dirty things that if they got on the concrete, my wife would NOT be pleased.
The horizontal mount of the oil filter is a really poor design.
I'm always on the hunt for TV boxes and similar to collect large sheets of cardboard.
lagolag
  • Sweden, Västra Götaland, Askim
« Reply #5 on: August 06, 2022, 19:10:09 »
This is a handy device that I use and store it under my 230SL when not used 8)
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
« Reply #6 on: August 06, 2022, 22:12:17 »
Really nice! Who makes that?
lagolag
« Reply #7 on: August 07, 2022, 12:03:55 »
I've bought mine locally in Sweden, they are called Quick jack, https://www.youtube.com/watch?v=604M7x7CfoY
EeVeeWee
« Reply #8 on: August 07, 2022, 14:34:20 »
I bought this one for in my garage, no regret at all.  ;D
Again something else.
« Reply #9 on: August 24, 2022, 15:07:42 »
Did you make those jack blocks, or jack plates, or whatever they're called, yourself?  That's pretty cool.
How can owners using the jacking holes ensure there is no rust that's hidden?
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #10 on: August 24, 2022, 15:54:36 »
Quick jack should be available from Costco.
Even harbour freight has a copy sometimes
The harbor freight mid rise hoist for $1,999 would be my choice -  its not bendpack quality but looks fine for our smaller cars.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
« Reply #11 on: August 24, 2022, 16:52:00 »
Lots of cars have horizontal mounted oil filters. Are they also of poor design?
I believe MB did that because of the oil cooler lines, which would also be poor design because of the larger engine requiring extra cooling.
BobH
« Reply #12 on: August 24, 2022, 17:21:33 »
I'm sure this has been covered umpteen times before, but to save me searching, on a 1965 230 that covers less than 3,000 miles per year, how often would you recommend the oil is changed?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Vander
  • USA, OH, Columbus
« Reply #13 on: August 24, 2022, 17:31:56 »
Once a year
« Reply #14 on: August 24, 2022, 17:40:43 »
Hopefully not hijacking the thread
I fully agree, once a year. Even sitting the oil can pick up moisture. It is a cheap, good practice.
BobH
« Reply #15 on: August 24, 2022, 18:04:23 »
Thank you both
UK delivered RHD
Blue soft top
Blue leather
« Reply #16 on: August 24, 2022, 18:33:42 »
If you make a mess removing (oil leaking out over frame and other parts) an oil filter due to its location, then yes, it's a poor design. Just because it's MB don't think everything they do is perfect. Does anyone remember their incredibly stupid bowing down to the "greenies" and putting self-destructing organic wiring insulation on their wiring harnesses? No other auto manufacturer did anything so incredibly poor in design or execution regarding wiring; pity the people that suffered with this nonsense.
In a commercial oil change place, they may, on a lift, be able to quickly remove the filter, and drop it in one of those elevated collection canisters. Perhaps a minimal mess, easily cleaned. Cleaning is much easier on a lift, rather than on your back, and even at a dealership, very difficult to do without leaking oil on parts in the way.  But really, is it necessary? A vertically mounted filter allows an oil change with little to no mess...which is a better design.
dirkbalter
  • USA, CA, Corona
« Reply #17 on: August 24, 2022, 19:32:13 »
Am I missing something? My oil filter is not mounted horizontally?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #18 on: August 24, 2022, 20:52:09 »
230 and 250 are vertical. 280 is mounted on an angle to clear the oil cooler lines.
« Reply #19 on: August 24, 2022, 21:01:43 »
That depends on what kind of oil you use and the type of driving you do. If you do mostly high speed, steady, open road driving, and you use synthetic oil, 3,000 miles is a waste. If you put around town using regular oil, 3,000 miles might be a good idea.
I have tractors and other farm machinery that get oil changes every 400 - 500 hours when recommended is every 100 hours* on regular 15 W 40.  I use a premium synthetic that has a TBN of 12 so it lasts a long time. We change oil filters at 100 - 200 hour intervals.
* one engine hour is roughly 60 miles.
BobH
« Reply #20 on: August 24, 2022, 21:14:44 »
Thank you Dan
UK delivered RHD
Blue soft top
Blue leather
lagolag
« Reply #21 on: August 24, 2022, 23:19:16 »
Yes, I’ve made them myself.
My car is rustfree, so I trust the jack points.
Oil change should be done every year but if it should be changed when the car is parked for the winter or taken out in the spring, I don’t know.
Bonnyboy
« Reply #22 on: August 25, 2022, 00:03:17 »
I have been told that its best if you are storing the vehicle over the winter to change oil before putting it away so it sits with fresh oil (but you have to promise not to start the car - not even once) and then you need to change again in the spring ... so most people I know just change in the spring because temptation gets the better of them and they will start the car up once or twice over the winter ....because thats what we do.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
JohnnyC
  • USA, CA, Escondido, CA
« Reply #23 on: August 25, 2022, 05:34:44 »
Really…, that’s the most ridiculous thing I’ve ever heard! Well, “And cows can fly” ?
Where and when did that myth start?
Mind as well leave it empty through the winter season and create more damage when you start it again 5 months later with fresh oil…, genius!
Then again, I do not live in that type of climate. So, perhaps I need to learn something about this way of preservation.
Cheers and God Bless,
JohnnyC
« Last Edit: August 25, 2022, 05:58:14 by JohnnyC »
John
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
« Reply #24 on: August 25, 2022, 05:49:03 »
Not as ridiculous as it may sound. While I have not heard any data-based facts on the matter, I have heard of two schools of thought. Both seem plausible.
First is change the oil prior to storage so your oil isn't sitting with its contaminants all winter. Changing the oil and the filter assures good clean oil for storage.
I have not heard the "not starting at all" but was always suggested that if I was going to start the car in the winter, then let it warm up, and run it for a bit. When my car was stored in Michigan over the winters for the first 20 years after restoration, I occasionally found myself at the storage location, no snow or moisture on the roads. So I could do it. The weather had to be in my favor however. This first thought--before--seems to be the prevailing thought.
The other school of thought is start the new season with fresh oil; any oil will accumulate moisture over long term (winter storage) so get whatever you have in there out at the start of the season.
