Author Topic: Headliner foam thickness 1/2 inch ok?  (Read 3689 times)
jzearfoss
  • USA, MT, Libby
« on: August 06, 2022, 23:49:59 »
I am replacing the headliner on my 1968 280 SL. Can anyone think of any reason I should not use 1/2 inch thick foam instead of the standard 1/8 inch thick?
1968 280 SL (AT)
2000 BMW Z3
1962 Pontiac Grand Prix
1951 Studebaker Commander
1937 Plymouth.
johnk
  • USA, OH, Avon
Re: Headliner foam thickness 1/2 inch ok?
« Reply #1 on: August 08, 2022, 03:42:53 »
You certainly would not want to use 1/2 inch on the front crossmember. That would not fit in well with the cut outs for the roof latches or for blending into the chrome trim pieces. Probably would also leave lines/protrusions against the support bars as I don’t thing they stick out 1/2 inch.  The more I think the more problems I can think of specially the sides of the hard top.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
carczar
  • USA, TX, Corpus Christi
Re: Headliner foam locations?
« Reply #2 on: June 01, 2024, 20:11:32 »
Where exactly is the hardtop foam supposed to go???  We used 1/4" adhesive backed industrial black sponge rubber and cut it to fit into the oval recesses and nowhere else... (since the original black foam had desintigrated) we have no idea what all should be getting a foam treatment.. Are there any illustrations showing where the foam is to be applied??
BobH
« Reply #3 on: June 01, 2024, 21:07:03 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
dodgert
  • USA, NC, Statesville
« Reply #4 on: June 07, 2024, 16:57:28 »
I'm getting my top ready for reassembly and have found this forum extremely helpful. One question I have about the foam choice. Does it have to be foam or can jute padding ,such as used under carpeting, be substituted? Of coarse the oval holes along the side would be opened up for proper airflow.
